Zum Hauptinhalt wechseln
Xbox One Wireless Controller Model 1708 Trigger Caps Replacement
Was du brauchst
  1. Xbox One Wireless Controller Model 1708 Trigger Caps Replacement, Trigger Caps: Schritt 1, Bild 1 von 2 Xbox One Wireless Controller Model 1708 Trigger Caps Replacement, Trigger Caps: Schritt 1, Bild 2 von 2
    • Slide the battery cover out and remove it.
    • Remove the battery pack.
  2. Xbox One Wireless Controller Model 1708 Trigger Caps Replacement: Schritt 2, Bild 1 von 3 Xbox One Wireless Controller Model 1708 Trigger Caps Replacement: Schritt 2, Bild 2 von 3 Xbox One Wireless Controller Model 1708 Trigger Caps Replacement: Schritt 2, Bild 3 von 3
    • Insert a plastic opening tool between the handle and the plate.
    • Gently slide the opening tool from the top end to the bottom end of the seam to remove the plate from the handle.
    • Repeat the process with the other side plate.
    • The plate is tightly sealed on the handle, so it may be difficult to remove.
  3. Xbox One Wireless Controller Model 1708 Trigger Caps Replacement: Schritt 3, Bild 1 von 2 Xbox One Wireless Controller Model 1708 Trigger Caps Replacement: Schritt 3, Bild 2 von 2
    • Remove the five 2.3mm screws on the bottom plate with a T8 Torx security Screwdriver.
    • If there is a sticker on the back, poke a hole with the screwdriver to get to the fifth screw.
  4. Xbox One Wireless Controller Model 1708 Trigger Caps Replacement: Schritt 4, Bild 1 von 2 Xbox One Wireless Controller Model 1708 Trigger Caps Replacement: Schritt 4, Bild 2 von 2
    • Remove the bottom plate.
  5. Xbox One Wireless Controller Model 1708 Trigger Caps Replacement: Schritt 5, Bild 1 von 3 Xbox One Wireless Controller Model 1708 Trigger Caps Replacement: Schritt 5, Bild 2 von 3 Xbox One Wireless Controller Model 1708 Trigger Caps Replacement: Schritt 5, Bild 3 von 3
    • Carefully turn over the controller with the front plate facing you.
    • Remove the front plate.
  6. Xbox One Wireless Controller Model 1708 Trigger Caps Replacement: Schritt 6, Bild 1 von 3 Xbox One Wireless Controller Model 1708 Trigger Caps Replacement: Schritt 6, Bild 2 von 3 Xbox One Wireless Controller Model 1708 Trigger Caps Replacement: Schritt 6, Bild 3 von 3
    • Remove the two 1.7mm screws from each of the triggers with a T6 Torx screwdriver.
    • It is best to do one trigger cap replacement at a time.
  7. Xbox One Wireless Controller Model 1708 Trigger Caps Replacement: Schritt 7, Bild 1 von 3 Xbox One Wireless Controller Model 1708 Trigger Caps Replacement: Schritt 7, Bild 2 von 3 Xbox One Wireless Controller Model 1708 Trigger Caps Replacement: Schritt 7, Bild 3 von 3
    • Be careful not to let the trigger motor inside come out.
    • Lift the trigger cap off the trigger motor.
  8. Xbox One Wireless Controller Model 1708 Trigger Caps Replacement: Schritt 8, Bild 1 von 3 Xbox One Wireless Controller Model 1708 Trigger Caps Replacement: Schritt 8, Bild 2 von 3 Xbox One Wireless Controller Model 1708 Trigger Caps Replacement: Schritt 8, Bild 3 von 3
    • Place the new trigger cap on the trigger motor.
    • Push down the inside of the trigger cap until you hear a click.
    • Repeat step six to eight for the other trigger cap.
Abschluss
To reassemble your device, follow steps 1-5 in reverse order.
16 weitere Nutzer:innen haben diese Anleitung absolviert.
UC Davis, Team S1-G6, Andersen Winter 2020 Mitglied von UC Davis, Team S1-G6, Andersen Winter 2020
UCD-ANDERSEN-W20S1G6
3 Mitglieder
3 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 17
Letzten 7 Tage: 104
Letzten 30 Tage: 438
Insgesamt: 13,613
