Zum Hauptinhalt wechseln
Xbox One X Project Scorpio Edition BD-ROM Drive Replacement
Was du brauchst
  1. Xbox One X Project Scorpio Edition BD-ROM Drive Replacement, Outer Case: Schritt 1, Bild 1 von 2 Xbox One X Project Scorpio Edition BD-ROM Drive Replacement, Outer Case: Schritt 1, Bild 2 von 2
    • Use a T9 Torx screwdriver to remove the 13mm screw which is under and to the left of the power input.
  2. Xbox One X Project Scorpio Edition BD-ROM Drive Replacement: Schritt 2, Bild 1 von 3 Xbox One X Project Scorpio Edition BD-ROM Drive Replacement: Schritt 2, Bild 2 von 3 Xbox One X Project Scorpio Edition BD-ROM Drive Replacement: Schritt 2, Bild 3 von 3
    • Using precision tweezers, remove the screw tab located on opposite side of the box.
    • Use a T9 Torx screwdriver to remove the 13mm screw revealed underneath the tab.
  3. Xbox One X Project Scorpio Edition BD-ROM Drive Replacement: Schritt 3, Bild 1 von 3 Xbox One X Project Scorpio Edition BD-ROM Drive Replacement: Schritt 3, Bild 2 von 3 Xbox One X Project Scorpio Edition BD-ROM Drive Replacement: Schritt 3, Bild 3 von 3
    • Orient the case so that the front of the Xbox (the side with the power button) is facing you.
    • Remove the top of the case by sliding the case towards you.
  4. Xbox One X Project Scorpio Edition BD-ROM Drive Replacement: Schritt 4, Bild 1 von 3 Xbox One X Project Scorpio Edition BD-ROM Drive Replacement: Schritt 4, Bild 2 von 3 Xbox One X Project Scorpio Edition BD-ROM Drive Replacement: Schritt 4, Bild 3 von 3
    • Using a T9 Torx screwdriver, remove the two 15mm silver screws that are holding a circuit board/panel to the side of the interior metal casing.
    • Using the same screwdriver, remove the 9mm black screw located farther to the right on the same circuit board/panel.
  5. Xbox One X Project Scorpio Edition BD-ROM Drive Replacement: Schritt 5, Bild 1 von 2 Xbox One X Project Scorpio Edition BD-ROM Drive Replacement: Schritt 5, Bild 2 von 2
    • Remove the unscrewed panel from the side of the device by pulling it toward you.
    • Be mindful of the connector, as it is fragile.
  6. Xbox One X Project Scorpio Edition BD-ROM Drive Replacement: Schritt 6, Bild 1 von 2 Xbox One X Project Scorpio Edition BD-ROM Drive Replacement: Schritt 6, Bild 2 von 2
    • Pull the upper edge of the white clip down, and then remove the white connector from the dislocated panel using precision tweezers.
    • Do not force the connector out, as it is fragile. Wiggling may be necessary.
  7. Xbox One X Project Scorpio Edition BD-ROM Drive Replacement: Schritt 7, Bild 1 von 3 Xbox One X Project Scorpio Edition BD-ROM Drive Replacement: Schritt 7, Bild 2 von 3 Xbox One X Project Scorpio Edition BD-ROM Drive Replacement: Schritt 7, Bild 3 von 3
    • On the top of the device in the corner directly above the white connector, there is an oval plate held in place by two screws.
    • Remove both of these 7mm screws with a Torx T9 screwdriver.
    • Lift the detached plate off to the side.
    • The plate is still connected to the device.
  8. Xbox One X Project Scorpio Edition BD-ROM Drive Replacement: Schritt 8, Bild 1 von 2 Xbox One X Project Scorpio Edition BD-ROM Drive Replacement: Schritt 8, Bild 2 von 2
    • Use a Torx T9 screwdriver to remove the six 47mm long screws, which attach the bottom side of the outer case.
  9. Xbox One X Project Scorpio Edition BD-ROM Drive Replacement: Schritt 9, Bild 1 von 3 Xbox One X Project Scorpio Edition BD-ROM Drive Replacement: Schritt 9, Bild 2 von 3 Xbox One X Project Scorpio Edition BD-ROM Drive Replacement: Schritt 9, Bild 3 von 3
    • Turn the Xbox over, so that the bottom of the case is on top.
    • Lift the bottom of the case off of the Xbox by pulling it up and toward you.
  10. Xbox One X Project Scorpio Edition BD-ROM Drive Replacement, BD-ROM Drive: Schritt 10, Bild 1 von 1
    • Flip over the device again, so that the top is facing upwards.
    • Remove the 4 smaller 11mm screws in the lower left corner on the metal casing using a Torx T9 screwdriver.
  11. Xbox One X Project Scorpio Edition BD-ROM Drive Replacement: Schritt 11, Bild 1 von 2 Xbox One X Project Scorpio Edition BD-ROM Drive Replacement: Schritt 11, Bild 2 von 2
    • Flip over the device again, so that the bottom is facing upwards.
    • Using a Torx T10 screwdriver, remove the two screws located on opposite sides of the metal casing. One is near the fan vent, and the other is near the power supply vent.
    • The left screw is 11mm and the right screw is 7.5 mm.
  12. Xbox One X Project Scorpio Edition BD-ROM Drive Replacement: Schritt 12, Bild 1 von 3 Xbox One X Project Scorpio Edition BD-ROM Drive Replacement: Schritt 12, Bild 2 von 3 Xbox One X Project Scorpio Edition BD-ROM Drive Replacement: Schritt 12, Bild 3 von 3
    • Remove the metal casing by pulling it upward, revealing the interior components of the device.
  13. Xbox One X Project Scorpio Edition BD-ROM Drive Replacement: Schritt 13, Bild 1 von 3 Xbox One X Project Scorpio Edition BD-ROM Drive Replacement: Schritt 13, Bild 2 von 3 Xbox One X Project Scorpio Edition BD-ROM Drive Replacement: Schritt 13, Bild 3 von 3
    • Lift and rotate the BD drive to reveal the wires that connect it to the motherboard.
  14. Xbox One X Project Scorpio Edition BD-ROM Drive Replacement: Schritt 14, Bild 1 von 3 Xbox One X Project Scorpio Edition BD-ROM Drive Replacement: Schritt 14, Bild 2 von 3 Xbox One X Project Scorpio Edition BD-ROM Drive Replacement: Schritt 14, Bild 3 von 3
    • Using your fingers, gently unplug the two sets of wires connecting the drive to the motherboard.
    • Alternatively, you can disconnect the wires from the drive-side sockets. This is much easier if you have not removed the power supply.
    • The BD drive should now be completely detached from the rest of the device, and it can be set aside.
Abschluss
4 weitere Nutzer:innen haben diese Anleitung absolviert.
Ashley Masuda
2.715 Reputation
7 Anleitungen geschrieben
Cal Poly, Team S2-G6, Livingston Winter 2018 Mitglied von Cal Poly, Team S2-G6, Livingston Winter 2018
CPSU-LIVINGSTON-W18S2G6
4 Mitglieder
23 Anleitungen geschrieben
5 Kommentare
ok it says no other parts required besides the tweezers and the t9 screw driver, but it doesn't mention what model of BD-ROM is suitable to replace it with.
Chris Storey - Antwort
The six long screws actually take a T-10 bit
mthouchen - Antwort
Please FIX Number 8 THIS IS NOT RIGHT!
Unfortunately the manual is not correct here. Above the black slot is a white switch / pen, fold it over with your fingernail, so fold it over to the front. Then the cable can be easily removed without any problems and tweezers. GERMAN: Hier ist die Anleitung leider nicht korrekt. Oberhalb des schwarzen Steckplatzes befindet sich ein weißer Schalter/Stift, diesen mit dem Fingernagel umklappen, also praktisch zu der Vorderseite umklappen. Danach lässt sich das Kabel ohne Probleme und Pinzette einfach abziehen.
Marcel - Antwort
What is the model of the BD ROM drive for the xBox 1 X?
Robb Applebee - Antwort
Followed this guide and https://www.youtube.com/watch?v=wO-QanKR... and upgraded my Xbox One X Project Scorpio edition to 2TB SSD. Thanks and keep up the good work
soorajlal - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 9
Letzte 30 Tage: 50
Insgesamt: 4,452
