Zum Hauptinhalt wechseln
Xbox Series X|S Controller (Model 1914) Left Handle Cover Replacement
Was du brauchst
  1. Xbox Series X|S Controller (Model 1914) Left Handle Cover Replacement, Insert an opening tool: Schritt 1, Bild 1 von 3 Xbox Series X|S Controller (Model 1914) Left Handle Cover Replacement, Insert an opening tool: Schritt 1, Bild 2 von 3 Xbox Series X|S Controller (Model 1914) Left Handle Cover Replacement, Insert an opening tool: Schritt 1, Bild 3 von 3
    • Insert an opening tool between the left handle cover and the bottom inner edge of the back housing.
  2. Xbox Series X|S Controller (Model 1914) Left Handle Cover Replacement, Release the left handle cover clips: Schritt 2, Bild 1 von 3 Xbox Series X|S Controller (Model 1914) Left Handle Cover Replacement, Release the left handle cover clips: Schritt 2, Bild 2 von 3 Xbox Series X|S Controller (Model 1914) Left Handle Cover Replacement, Release the left handle cover clips: Schritt 2, Bild 3 von 3
    • Strong plastic clips secure the handle cover. Significant force is required to release them.
    • Slide the opening tool along the inner edge of the left handle cover and pry intermittently to release the plastic clips.
  3. Xbox Series X|S Controller (Model 1914) Left Handle Cover Replacement, Remove the left handle cover: Schritt 3, Bild 1 von 3 Xbox Series X|S Controller (Model 1914) Left Handle Cover Replacement, Remove the left handle cover: Schritt 3, Bild 2 von 3 Xbox Series X|S Controller (Model 1914) Left Handle Cover Replacement, Remove the left handle cover: Schritt 3, Bild 3 von 3
    • The plastic clips on the outer edge make it difficult to slide along it and release the clips. Therefore, prying up on the inner edge is the easier option.
    • Pry up the middle inner edge of the handle cover with the opening tool to release the remaining clips.
    • Place a finger on top of the handle cover to prevent it from being forcefully ejected.
    • Remove the left handle cover.
    • To reinstall the left handle cover, position it on the back housing and press down firmly along the edges to engage all of the clips.
Abschluss
Manuel Haeussermann
14.243 Reputation
71 Anleitungen geschrieben
iFixit Mitglied von iFixit
Community
142 Mitglieder
16.239 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 6
Letzte 7 Tage: 25
Letzte 30 Tage: 100
Insgesamt: 653
