Zum Hauptinhalt wechseln
Xbox Series X 2TB Galaxy Black Motherboard Replacement
Was du brauchst
  1. Xbox Series X 2TB Galaxy Black Motherboard Replacement, Uncover the back panel screws: Schritt 1, Bild 1 von 2 Xbox Series X 2TB Galaxy Black Motherboard Replacement, Uncover the back panel screws: Schritt 1, Bild 2 von 2
    • Before you begin, completely power down and unplug all cables from your console.
    • Use a pair of tweezers to remove the sticker hiding the first screw on the back panel, near the base.
  2. Xbox Series X 2TB Galaxy Black Motherboard Replacement: Schritt 2, Bild 1 von 3 Xbox Series X 2TB Galaxy Black Motherboard Replacement: Schritt 2, Bild 2 von 3 Xbox Series X 2TB Galaxy Black Motherboard Replacement: Schritt 2, Bild 3 von 3
    • For cleaner removal, use an iOpener or hair dryer to heat the sticker.
    • Use a pair of tweezers or a sharp blade to peel up a corner of the large sticker on the back panel. Use your fingers to peel it farther, just enough to reveal the second screw.
    • You only need to peel this sticker to where you can access the hidden screw. You don't need to pull it completely off.
    • Technically, these are tamper-evident stickers, but don't worry—Microsoft can't legally void your warranty, as long as you don't damage anything. Have fun!
  3. Xbox Series X 2TB Galaxy Black Motherboard Replacement, Remove the back panel screws: Schritt 3, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    Magnetic Project Mat
    $19.95
    • Use a T8 Torx driver to remove the two 7.4 mm‑long screws securing the back panel.
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your console.
  4. Xbox Series X 2TB Galaxy Black Motherboard Replacement, Unclip the back panel: Schritt 4, Bild 1 von 3 Xbox Series X 2TB Galaxy Black Motherboard Replacement, Unclip the back panel: Schritt 4, Bild 2 von 3 Xbox Series X 2TB Galaxy Black Motherboard Replacement, Unclip the back panel: Schritt 4, Bild 3 von 3
    • Insert the flat end of a spudger into the gap between the back panel and the shell, near the left side of the base.
    • Pry up the back panel to release it from the locking clips.
  5. Xbox Series X 2TB Galaxy Black Motherboard Replacement: Schritt 5, Bild 1 von 2 Xbox Series X 2TB Galaxy Black Motherboard Replacement: Schritt 5, Bild 2 von 2
    • Insert the flat end of a spudger into the gap between the back panel and the shell, near the right side of the base.
  6. Xbox Series X 2TB Galaxy Black Motherboard Replacement, Remove the back panel: Schritt 6, Bild 1 von 3 Xbox Series X 2TB Galaxy Black Motherboard Replacement, Remove the back panel: Schritt 6, Bild 2 von 3 Xbox Series X 2TB Galaxy Black Motherboard Replacement, Remove the back panel: Schritt 6, Bild 3 von 3
    • Grip the back panel at the opening you just created and pull it up and away from the shell to unclip the long edges.
    • During reassembly, press along the edges of the back panel to snap it into place.
  7. Xbox Series X 2TB Galaxy Black Motherboard Replacement: Schritt 7, Bild 1 von 3 Xbox Series X 2TB Galaxy Black Motherboard Replacement: Schritt 7, Bild 2 von 3 Xbox Series X 2TB Galaxy Black Motherboard Replacement: Schritt 7, Bild 3 von 3
    • The back panel slots into a gap at the top of the shell.
    • Tilt the back panel up and pull it away from the top edge of the shell to release it from the gap.
    • Remove the back panel.
  8. Xbox Series X 2TB Galaxy Black Motherboard Replacement, Remove the fan screws: Schritt 8, Bild 1 von 1
    • Use a T8 Torx driver to remove the three screws securing the fan to the center chassis:
    • One 10.5 mm pancake screw
    • Two 8.8 mm screws
  9. Xbox Series X 2TB Galaxy Black Motherboard Replacement, Disconnect the fan cable: Schritt 9, Bild 1 von 3 Xbox Series X 2TB Galaxy Black Motherboard Replacement, Disconnect the fan cable: Schritt 9, Bild 2 von 3 Xbox Series X 2TB Galaxy Black Motherboard Replacement, Disconnect the fan cable: Schritt 9, Bild 3 von 3
    • Use your fingers or a pair of blunt tweezers to grip the edges of the fan cable connector, and pull up to disconnect it from the center chassis.
    • Always pull cables by their connectors and not the wires themselves.
    • During reassembly, route the fan cable underneath its small cable guide on the fan housing so it doesn't interfere with the back panel.
  10. Xbox Series X 2TB Galaxy Black Motherboard Replacement, Remove the fan: Schritt 10, Bild 1 von 2 Xbox Series X 2TB Galaxy Black Motherboard Replacement, Remove the fan: Schritt 10, Bild 2 von 2
    • Slide the fan out of its slot to remove it.
    • During reinstallation, note that the fan can only be installed one way—make sure Master Chief is facing you.
    • If you're replacing the fan, a new fan might not include the plastic installation bracket, which is attached to the fan with four T10 Torx screws. This isn't pictured in this guide.
  11. Xbox Series X 2TB Galaxy Black Motherboard Replacement, Unlatch the base: Schritt 11, Bild 1 von 2 Xbox Series X 2TB Galaxy Black Motherboard Replacement, Unlatch the base: Schritt 11, Bild 2 von 2
    • Use the flat end of a spudger to lift up on the locking tab holding the base to the shell.
  12. Xbox Series X 2TB Galaxy Black Motherboard Replacement, Twist and remove the base: Schritt 12, Bild 1 von 3 Xbox Series X 2TB Galaxy Black Motherboard Replacement, Twist and remove the base: Schritt 12, Bild 2 von 3 Xbox Series X 2TB Galaxy Black Motherboard Replacement, Twist and remove the base: Schritt 12, Bild 3 von 3
    • With the locking tab held open, grip the base and rotate it counterclockwise to unlock it from the shell.
    • Remove the base.
    • During reassembly, put the base tabs into their holes on the shell and twist clockwise until the base snaps into the interior locking tab.
    • When locked in place, the "Hello from Seattle" line will be parallel with the device's sides.
  13. Xbox Series X 2TB Galaxy Black Motherboard Replacement, Remove the optical drive screws: Schritt 13, Bild 1 von 2 Xbox Series X 2TB Galaxy Black Motherboard Replacement, Remove the optical drive screws: Schritt 13, Bild 2 von 2
    • Use a T8 Torx driver to remove the two 8.8 mm screws securing the optical drive's vibration isolator to the shell: one on the base and one on the top of the isolator.
  14. Xbox Series X 2TB Galaxy Black Motherboard Replacement, Remove the vibration isolator: Schritt 14, Bild 1 von 3 Xbox Series X 2TB Galaxy Black Motherboard Replacement, Remove the vibration isolator: Schritt 14, Bild 2 von 3 Xbox Series X 2TB Galaxy Black Motherboard Replacement, Remove the vibration isolator: Schritt 14, Bild 3 von 3
    • Lift up the optical drive's vibration isolator to remove it.
    • The vibration isolator grips the sides of the optical drive with silicone pads, so you may need to "walk" the isolator off of the drive to slip it off each side.
    • During reassembly, ensure the vibration isolator is pushed down and around both edges of the optical drive, so it sits flush with the rest of the center chassis.
  15. Xbox Series X 2TB Galaxy Black Motherboard Replacement, Disconnect the power and data cables: Schritt 15, Bild 1 von 3 Xbox Series X 2TB Galaxy Black Motherboard Replacement, Disconnect the power and data cables: Schritt 15, Bild 2 von 3 Xbox Series X 2TB Galaxy Black Motherboard Replacement, Disconnect the power and data cables: Schritt 15, Bild 3 von 3
    • Use a pair of blunt tweezers to grip the edges of the optical drive power connector and pull up to disconnect it from the optical drive.
    • Use your fingers to pull up and disconnect the data cable from the optical drive.
  16. Xbox Series X 2TB Galaxy Black Motherboard Replacement, Remove the optical drive: Schritt 16, Bild 1 von 2 Xbox Series X 2TB Galaxy Black Motherboard Replacement, Remove the optical drive: Schritt 16, Bild 2 von 2
    • Grip the top edge of the optical drive and pull it out of its slot in the shell to remove it.
    • During reassembly, align the pegs on the bottom edge of the optical drive with the guide holes on the bottom of the shell.
    • If the drive is misaligned, the top vibration isolator will not be able to be installed correctly, and the disc reader will be misaligned with the front of the console.
  17. Xbox Series X 2TB Galaxy Black Motherboard Replacement, Xbox Series X 2TB Galaxy Black Chassis Removal: Schritt 17, Bild 1 von 3 Xbox Series X 2TB Galaxy Black Motherboard Replacement, Xbox Series X 2TB Galaxy Black Chassis Removal: Schritt 17, Bild 2 von 3 Xbox Series X 2TB Galaxy Black Motherboard Replacement, Xbox Series X 2TB Galaxy Black Chassis Removal: Schritt 17, Bild 3 von 3
    • The ribbon cables and their connectors are extremely fragile, so always open locking tabs gently and pull cables slowly.
    • Use the flat end of a spudger to flip open the metal locking tab on the USB port ribbon cable.
    • During reassembly, gently snap the metal locking tab back into place once the cable has been inserted.
  18. Xbox Series X 2TB Galaxy Black Motherboard Replacement: Schritt 18, Bild 1 von 2 Xbox Series X 2TB Galaxy Black Motherboard Replacement: Schritt 18, Bild 2 von 2
    • Use a pair of tweezers to pull up on the black plastic pull tab to disconnect the USB port cable.
    • Pull only on the pull tab, not the cable itself.
    • If the USB port cable feels adhered to the metal chassis, use an apply an iOpener or hair dryer to heat the cable. Depending on your model of Xbox, you may also need to slide an opening pick under the cable to separate the adhesive.
  19. Xbox Series X 2TB Galaxy Black Motherboard Replacement, Disconnect the power button cable: Schritt 19, Bild 1 von 3 Xbox Series X 2TB Galaxy Black Motherboard Replacement, Disconnect the power button cable: Schritt 19, Bild 2 von 3 Xbox Series X 2TB Galaxy Black Motherboard Replacement, Disconnect the power button cable: Schritt 19, Bild 3 von 3
    • Use the pointed end of a spudger to depress the metal tab on the side of the power button cable's board connector.
    • With the metal tab depressed, use a pair of tweezers to pull up on the pull tab to disconnect the power button cable from the center chassis.
    • Don't pull on the cable without depressing the metal tab, otherwise you risk damaging either the cable or the connector.
    • During reassembly, the cable should lightly "snap" into place when inserted.
  20. Xbox Series X 2TB Galaxy Black Motherboard Replacement, Remove the chassis screws: Schritt 20, Bild 1 von 2 Xbox Series X 2TB Galaxy Black Motherboard Replacement, Remove the chassis screws: Schritt 20, Bild 2 von 2
    • Use a T8 Torx driver to remove the three 7.4 mm screws securing the center chassis assembly to the shell.
  21. Xbox Series X 2TB Galaxy Black Motherboard Replacement: Schritt 21, Bild 1 von 2 Xbox Series X 2TB Galaxy Black Motherboard Replacement: Schritt 21, Bild 2 von 2
    • Gently peel the taped USB port ribbon cable off of the heatsink.
    • Depending on your model of Xbox, the adhesive may be on the underside of the cable. If so, use an iOpener or hair dryer to heat the cable.
  22. Xbox Series X 2TB Galaxy Black Motherboard Replacement: Schritt 22, Bild 1 von 3 Xbox Series X 2TB Galaxy Black Motherboard Replacement: Schritt 22, Bild 2 von 3 Xbox Series X 2TB Galaxy Black Motherboard Replacement: Schritt 22, Bild 3 von 3
    • The center chassis assembly is aligned to the bottom of the shell with guide pegs. These pegs will need to slide out of their slots to allow the chassis to be lifted out.
    • Grip the chassis and pull it towards the top of the shell, uncoupling the guide pegs from the shell.
    • Use two hands to lift out the chassis to remove it from the shell.
    • During reassembly, make sure neither of the ribbon cables get pinched as you lower the center chassis into the shell.
  23. Xbox Series X 2TB Galaxy Black Motherboard Replacement: Schritt 23, Bild 1 von 2 Xbox Series X 2TB Galaxy Black Motherboard Replacement: Schritt 23, Bild 2 von 2
    Dust Blower
    $5.99
    • Gently place the chassis heatsink-side down on a clean work surface.
    • During reassembly, this is a good point to clean the heatsink fins of any dust, dirt, or debris that may have built up over time. Use a dust blower or compressed air to clear out the fins.
  24. Xbox Series X 2TB Galaxy Black Motherboard Replacement, Remove the antenna board screws: Schritt 24, Bild 1 von 2 Xbox Series X 2TB Galaxy Black Motherboard Replacement, Remove the antenna board screws: Schritt 24, Bild 2 von 2
    • Use a T8 Torx driver to remove the three 9.6 mm‑long screws securing the antenna board to the center chassis.
  25. Xbox Series X 2TB Galaxy Black Motherboard Replacement, Remove the accessory antenna board: Schritt 25, Bild 1 von 3 Xbox Series X 2TB Galaxy Black Motherboard Replacement, Remove the accessory antenna board: Schritt 25, Bild 2 von 3 Xbox Series X 2TB Galaxy Black Motherboard Replacement, Remove the accessory antenna board: Schritt 25, Bild 3 von 3
    • Grip the top right corner of the antenna board and pull it directly away from the center chassis to disconnect it.
    • During reassembly, align the board's connector with the port on the center chassis and press to reconnect.
  26. Xbox Series X 2TB Galaxy Black Motherboard Replacement, Remove the power cable port: Schritt 26, Bild 1 von 2 Xbox Series X 2TB Galaxy Black Motherboard Replacement, Remove the power cable port: Schritt 26, Bild 2 von 2
    • Use a T8 Torx driver to remove the three screws securing the power cable port to the chassis:
    • Two 13.1 mm‑long screws
    • One 35 mm‑long screw
  27. Xbox Series X 2TB Galaxy Black Motherboard Replacement: Schritt 27, Bild 1 von 2 Xbox Series X 2TB Galaxy Black Motherboard Replacement: Schritt 27, Bild 2 von 2
    • Lift the power connector out of its recess in the chassis.
  28. Xbox Series X 2TB Galaxy Black Motherboard Replacement, De-route the power cables: Schritt 28, Bild 1 von 2 Xbox Series X 2TB Galaxy Black Motherboard Replacement, De-route the power cables: Schritt 28, Bild 2 von 2
    • Unlatch and open the lid on the power cable's plastic guide.
  29. Xbox Series X 2TB Galaxy Black Motherboard Replacement: Schritt 29, Bild 1 von 2 Xbox Series X 2TB Galaxy Black Motherboard Replacement: Schritt 29, Bild 2 von 2
    • Lift the power cable out from underneath the extra section of the cable guide.
  30. Xbox Series X 2TB Galaxy Black Motherboard Replacement, Remove the board shield: Schritt 30, Bild 1 von 2 Xbox Series X 2TB Galaxy Black Motherboard Replacement, Remove the board shield: Schritt 30, Bild 2 von 2
    • Use a T8 Torx driver to remove the ten screws securing the board shield:
    • Seven 8.7 mm‑long screws
    • Two 35 mm‑long screws
    • These screws are very tight and may take significant force to loosen.
    • One 13 mm‑long screw
  31. Xbox Series X 2TB Galaxy Black Motherboard Replacement: Schritt 31, Bild 1 von 3 Xbox Series X 2TB Galaxy Black Motherboard Replacement: Schritt 31, Bild 2 von 3 Xbox Series X 2TB Galaxy Black Motherboard Replacement: Schritt 31, Bild 3 von 3
    • Hold the power supply cable out of the way and lift the board shield straight up to remove it.
  32. Xbox Series X 2TB Galaxy Black Motherboard Replacement, Disconnect the power supply cables: Schritt 32, Bild 1 von 3 Xbox Series X 2TB Galaxy Black Motherboard Replacement, Disconnect the power supply cables: Schritt 32, Bild 2 von 3 Xbox Series X 2TB Galaxy Black Motherboard Replacement, Disconnect the power supply cables: Schritt 32, Bild 3 von 3
    • Open the lid on the power supply's plastic cable guide.
  33. Xbox Series X 2TB Galaxy Black Motherboard Replacement: Schritt 33, Bild 1 von 3 Xbox Series X 2TB Galaxy Black Motherboard Replacement: Schritt 33, Bild 2 von 3 Xbox Series X 2TB Galaxy Black Motherboard Replacement: Schritt 33, Bild 3 von 3
    • Use your fingers to pinch the power supply's 10‑pin power connector, so the locking tab opens outward.
    • With the locking tab open, lift the connector straight up and out of its socket.
  34. Xbox Series X 2TB Galaxy Black Motherboard Replacement, Disconnect the interconnect cable: Schritt 34, Bild 1 von 3 Xbox Series X 2TB Galaxy Black Motherboard Replacement, Disconnect the interconnect cable: Schritt 34, Bild 2 von 3 Xbox Series X 2TB Galaxy Black Motherboard Replacement, Disconnect the interconnect cable: Schritt 34, Bild 3 von 3
    • Use your fingers to pinch the locking tab in the center of the interconnect cable connector.
    • While pinching the tab, insert the flat end of a spudger between the top of the socket and the connector's tab.
    • Twist the spudger to lift the connector out of its socket until the clip in the center disengages.
  35. Xbox Series X 2TB Galaxy Black Motherboard Replacement: Schritt 35, Bild 1 von 2 Xbox Series X 2TB Galaxy Black Motherboard Replacement: Schritt 35, Bild 2 von 2
    • Use your fingers to pull the connector straight up and out of its socket.
    • During reassembly, insert the interconnect cable connector into its socket and press down on both edges until the connector snaps into place.
  36. Xbox Series X 2TB Galaxy Black Motherboard Replacement, Unlatch the chassis strap: Schritt 36, Bild 1 von 3 Xbox Series X 2TB Galaxy Black Motherboard Replacement, Unlatch the chassis strap: Schritt 36, Bild 2 von 3 Xbox Series X 2TB Galaxy Black Motherboard Replacement, Unlatch the chassis strap: Schritt 36, Bild 3 von 3
    • Pull the rubber strap down and away from the chassis to unlatch it.
  37. Xbox Series X 2TB Galaxy Black Motherboard Replacement: Schritt 37, Bild 1 von 3 Xbox Series X 2TB Galaxy Black Motherboard Replacement: Schritt 37, Bild 2 von 3 Xbox Series X 2TB Galaxy Black Motherboard Replacement: Schritt 37, Bild 3 von 3
    • Pull the chassis strap off its three alignment posts and unlatch it from the sides of the power supply.
    • You can leave the strap under the chassis or remove it.
    • During reassembly, make sure the nubs in the middle of the strap go unto their cutouts on the heat sink fins.
  38. Xbox Series X 2TB Galaxy Black Motherboard Replacement, Remove the silver power supply screws: Schritt 38, Bild 1 von 2 Xbox Series X 2TB Galaxy Black Motherboard Replacement, Remove the silver power supply screws: Schritt 38, Bild 2 von 2
    • Use a T8 Torx driver to remove the three 35 mm‑long silver screws from the power supply—leave the fourth black screw in place.
  39. Xbox Series X 2TB Galaxy Black Motherboard Replacement, Remove the center chassis: Schritt 39, Bild 1 von 3 Xbox Series X 2TB Galaxy Black Motherboard Replacement, Remove the center chassis: Schritt 39, Bild 2 von 3 Xbox Series X 2TB Galaxy Black Motherboard Replacement, Remove the center chassis: Schritt 39, Bild 3 von 3
    • Grip the edges of the center chassis (not the power supply) and lift it off the motherboard and heatsink assembly, routing the interconnect cable through its cutout.
  40. Xbox Series X 2TB Galaxy Black Motherboard Replacement, Remove the SSD: Schritt 40, Bild 1 von 2 Xbox Series X 2TB Galaxy Black Motherboard Replacement, Remove the SSD: Schritt 40, Bild 2 von 2
    • Use a T8 Torx driver to remove the 5.1 mm‑long screw securing the SSD.
    • With the SSD screw removed, the SSD will pop up at a shallow angle.
  41. Xbox Series X 2TB Galaxy Black Motherboard Replacement: Schritt 41, Bild 1 von 2 Xbox Series X 2TB Galaxy Black Motherboard Replacement: Schritt 41, Bild 2 von 2
    • Grip the end of the SSD and pull it away from its M.2 board connector to remove it.
    • During reassembly, insert the SSD at a shallow angle into its board connector, and secure it back into its horizontal position with the SSD screw.
  42. Xbox Series X 2TB Galaxy Black Motherboard Replacement, Remove the interconnect cable: Schritt 42, Bild 1 von 3 Xbox Series X 2TB Galaxy Black Motherboard Replacement, Remove the interconnect cable: Schritt 42, Bild 2 von 3 Xbox Series X 2TB Galaxy Black Motherboard Replacement, Remove the interconnect cable: Schritt 42, Bild 3 von 3
    • Pinch the locking tab on the interconnect cable on the motherboard and use the flat end of a spudger to disengage the clip.
    • During reassembly, insert the #1—SOC side of interconnect cable connector into its socket so the locking tab is facing outward. Then, press down on the edges of the connector until it snaps into place.
  43. Xbox Series X 2TB Galaxy Black Motherboard Replacement, Remove the APU tension bracket: Schritt 43, Bild 1 von 2 Xbox Series X 2TB Galaxy Black Motherboard Replacement, Remove the APU tension bracket: Schritt 43, Bild 2 von 2
    • Only loosen and tighten the APU tension bracket screws a few turns at a time in an "X" pattern. For example: top left → bottom right → top right → bottom left.
    • Use a T8 Torx driver to remove the four 12.4 mm‑long APU tension bracket screws.
  44. Xbox Series X 2TB Galaxy Black Motherboard Replacement: Schritt 44, Bild 1 von 2 Xbox Series X 2TB Galaxy Black Motherboard Replacement: Schritt 44, Bild 2 von 2
    • Don't move the APU bracket side to side, or you may damage the delicate surface‑mounted components underneath it. Only lift straight up.
    • Use your fingers to lift the APU bracket straight up and remove it.
    • During reassembly, set the bracket into place so the black pieces of plastic are facing the short edges of the motherboard—the piece of plastic with a circular hole (not oblong) should be closer to the SSD socket. Use this photo as a reference.
  45. Xbox Series X 2TB Galaxy Black Motherboard Replacement, Remove the motherboard: Schritt 45, Bild 1 von 3 Xbox Series X 2TB Galaxy Black Motherboard Replacement, Remove the motherboard: Schritt 45, Bild 2 von 3 Xbox Series X 2TB Galaxy Black Motherboard Replacement, Remove the motherboard: Schritt 45, Bild 3 von 3
    • Depending on the condition of the thermal paste and putty, the board may be bonded to the heatsink assembly. If you can't easily remove the board, use a spudger to gently lift the edges of the board to separate it.
    • Use your fingers to lift the motherboard straight up and off the heatsink to remove it.
    • During reassembly, carefully place the board onto the heatsink with the APU facing down. Remember, there's exposed thermal paste on the bottom of the board, so use the alignment pegs to orient it correctly. If you have to reposition the board, it may smear the thermal paste.
  46. Xbox Series X 2TB Galaxy Black Motherboard Replacement, Replace the thermal pads: Schritt 46, Bild 1 von 2 Xbox Series X 2TB Galaxy Black Motherboard Replacement, Replace the thermal pads: Schritt 46, Bild 2 von 2
    • Check the condition of the thermal putty—it'll be on the heatsink and/or the motherboard.
    • If any pieces are damaged or dried out, follow the next four steps to remove and replace them.
    • If you're only replacing the thermal paste, skip to this step.
  47. Xbox Series X 2TB Galaxy Black Motherboard Replacement: Schritt 47, Bild 1 von 3 Xbox Series X 2TB Galaxy Black Motherboard Replacement: Schritt 47, Bild 2 von 3 Xbox Series X 2TB Galaxy Black Motherboard Replacement: Schritt 47, Bild 3 von 3
    • Use the flat end of a spudger to scrape off the damaged or deteriorated thermal pad.
    • Be careful around any small surface-mounted components that might be hidden under the thermal pad. Work slowly to avoid accidentally prying them off.
  48. Xbox Series X 2TB Galaxy Black Motherboard Replacement: Schritt 48, Bild 1 von 2 Xbox Series X 2TB Galaxy Black Motherboard Replacement: Schritt 48, Bild 2 von 2
    Cotton Swabs
    • Use isopropyl alcohol (>90%) and a lint-free microfiber cloth to remove any thermal putty residue.
    • If you have to work near the small resistors, use cotton swabs instead.
  49. Xbox Series X 2TB Galaxy Black Motherboard Replacement: Schritt 49, Bild 1 von 2 Xbox Series X 2TB Galaxy Black Motherboard Replacement: Schritt 49, Bild 2 von 2
    • To prevent the thermal putty from sticking to your fingers, consider wearing nitrile gloves.
    • Grab a small piece of thermal putty. Refer to the size of the thermal pad you're replacing for how much you need.
  50. Xbox Series X 2TB Galaxy Black Motherboard Replacement: Schritt 50, Bild 1 von 2 Xbox Series X 2TB Galaxy Black Motherboard Replacement: Schritt 50, Bild 2 von 2
    • Roll the thermal putty into a ball.
    • Place the thermal putty where the damaged thermal pad was, making sure it's centered over the component—in this case a memory chip.
    • Optionally, you can use the flat end of a spudger (or an included applicator) to spread the thermal putty over the surface of the component.
    • When you reattach the heat sink, you'll compress the thermal putty and it'll spread the ball out.
  51. Xbox Series X 2TB Galaxy Black Motherboard Replacement, Replace the thermal paste: Schritt 51, Bild 1 von 2 Xbox Series X 2TB Galaxy Black Motherboard Replacement, Replace the thermal paste: Schritt 51, Bild 2 von 2
    Cotton Swabs
    • Apply a few drops of isopropyl alcohol (>90%) to the processor and use a coffee filter or a lint-free cloth to wipe away any residue.
  52. Xbox Series X 2TB Galaxy Black Motherboard Replacement: Schritt 52, Bild 1 von 2 Xbox Series X 2TB Galaxy Black Motherboard Replacement: Schritt 52, Bild 2 von 2
    • Repeat the previous step for the thermal paste on the heat sink.
    • You can use a spudger to scrape off the thermal paste on the heat sink if it's too dried out.
  53. Xbox Series X 2TB Galaxy Black Motherboard Replacement, Apply the thermal paste: Schritt 53, Bild 1 von 2 Xbox Series X 2TB Galaxy Black Motherboard Replacement, Apply the thermal paste: Schritt 53, Bild 2 von 2
    • Apply a small bead of thermal paste to the center of the APU.
    • Follow this guide in reverse order starting with this step to reattach the heat sink. Placing the heat sink back on the processor will evenly spread the thermal paste (and thermal putty if applicable) and bond both parts together.
Abschluss
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Xbox Series X Answers community for help.
Eine weitere Person hat diese Anleitung absolviert.
Spencer Day
162.479 Reputation
1.043 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
124 Mitglieder
24.164 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 6
Letzte 7 Tage: 34
Letzte 30 Tage: 170
Insgesamt: 1,518
