Zum Hauptinhalt wechseln
Xbox Series X Drahtloser Controller Zerlegung
Was du brauchst
Videoanleitungen
Abschluss
Um dein Gerät wieder zusammenzubauen, folge den Schritten dieser Anleitung in umgekehrter Reihenfolge.
26 weitere Personen haben diese Anleitung absolviert.
en de
100%
Hier starten ›
Arty
32.937 Reputation
110 Anleitungen geschrieben
6 Kommentare zur Anleitung
So, is the joystick of series s/x the same as that of its predecessor ones onex?
kasynlife - Antwort Teilen
I'm sure you know but yes they are the same
Joshua Llarinas - Antwort Teilen
This was a pain just to get to one button that was sticking. Luckily I didn't break my controller, especially those tiny wires for the trigger motors.
Is it permissible to use this guide to try and tear down a series 2?
Taylor Reynolds - Antwort Teilen
Told a student of mine that replacing the USB port would be a piece of cake. I have 6 different kinds of USB-C receptacles in my supplies drawers, thought for sure I'd be able to impress them. Turns out I was wrong. the USB port they use has pins buried in places it's impossible to get to. They wrap the whole socket with a metal cover, trying to give the appearance that it's "reinforced", but when you get that cover off you can clearly see these are designed to fail. No way to reflow these with hot air or hotplate. So frustrating!
Jon Dresser - Antwort Teilen
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 28
Letzte 7 Tage: 322
Letzte 30 Tage: 1,565
Insgesamt: 74,247
