Was du brauchst
You can either remove the labels or simply feel for the screw holes through the labels and then cut or punch a hole through them.
Once the bottom and top shells are no longer attached, carefully turn the Xbox right-side-up, lift and remove the top cover.
Free the hard drive power cable from the carrier for sufficient slack to lift the hard drive out.
Lift the plastic hard drive carrier out of the Xbox case.
Remove the four 3.4 mm T15 Torx screws from the plastic hard drive carrier (two screws per side).
Carefully remove the hard drive from the plastic carrier. Gentle rocking will see the hard drive come out quite easily.
Pull both the hard drive data ribbon cable and the power cable straight up from the hard drive.
Remove the disk drive. It should come right out.
Unplug the ribbon cable and yellow cables from back of disk drive.
Pry back the black plastic tabs around the disk drive in order to remove it from its housing. Once removed, set the drive aside.
Remove two #1 PH screws
Remove upper metal housing
Remove two T10 Screws
Remove lower metal housing
Remove two PH1 screws
Gently pull up on the ribbon retaining tab. Do NOT pull on ribbon. It will slide itself out in final step
Gently pull up on the ribbon retaining tab. Ribbon is attached to underside of PCB via a sticky pad. Gently pull the ribbon away from pad
Desolder both points. Red (Left) Black (Right)
Gently press up on the PCB where you removed the two PH1 screws and rotate the board upside down
With the drive upside down slide the white lever to the right
Flip the drive over and slowly pull the door out
Apply grease to highlighted areas
Apply a liberal glob of grease along the tooth track and insert/withdraw the drive door a few times to easily lubricate the gears highlighted pink
With a cotton swab, gently clean your laser with 91% or higher isopropyl alcohol
2 weitere Personen haben diese Anleitung absolviert.
3 Kommentare
What is the plastic disk at the top of the drive above where the dvd sits is called?
can it cause error 12 even if it opens drive? talking 1st gen xbox i also move the laser am not sure if i need to realign the spinning disc or both?
laser did get clean but even with opening drive gets error 12….
