Einleitung
Removing the back cover of the Xelio P1001A-BK tablet is fairly simple and straightforward.
There are four securing tabs along both long sides of the tablet shells which are disengaged by gently prying them apart with an opening tool. The speakers reside in two housings on the back shell half and connect to the motherboard with two very thin wires each. The tablet speakers have magnets on their backs which should make them stick to the metal shell protecting the back of the screen. However, if the speakers stay attached to the back shell half, gently pry them out of the sockets before completely separating the shell halves.
Was du brauchst
Remove the two 3 mm retaining screws from the side of the tablet with a Phillips #0 screwdriver.
Insert the plastic opening tool in between the shelf halves and lift the top shelf half to detach the securing tabs.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
