Zum Hauptinhalt wechseln
Xelio P1001A-BK Wi-Fi Antenna Replacement
Was du brauchst
  1. Xelio P1001A-BK Wi-Fi Antenna Replacement, Back Cover: Schritt 1, Bild 1 von 2 Xelio P1001A-BK Wi-Fi Antenna Replacement, Back Cover: Schritt 1, Bild 2 von 2
    • Remove the two 3 mm retaining screws from the side of the tablet with a Phillips #0 screwdriver.
  2. Xelio P1001A-BK Wi-Fi Antenna Replacement: Schritt 2, Bild 1 von 2 Xelio P1001A-BK Wi-Fi Antenna Replacement: Schritt 2, Bild 2 von 2
    • Insert the plastic opening tool in between the shelf halves and lift the top shelf half to detach the securing tabs.
    • There are four securing tabs located on each long side.
    • Before fully separating the shell halves, observe if the speakers are separated from the shell half. If they are still in their sockets, gently pry them loose with the plastic opening tool.
  3. Xelio P1001A-BK Wi-Fi Antenna Replacement, Wi-Fi Antenna: Schritt 3, Bild 1 von 2 Xelio P1001A-BK Wi-Fi Antenna Replacement, Wi-Fi Antenna: Schritt 3, Bild 2 von 2
    • Desolder the connection on the motherboard.
    • Use a soldering vacuum to remove any excess solder.
  4. Xelio P1001A-BK Wi-Fi Antenna Replacement: Schritt 4, Bild 1 von 1
    • Use wire strippers to strip off at least 2 mm of wire insulation from each wire.
  5. Xelio P1001A-BK Wi-Fi Antenna Replacement: Schritt 5, Bild 1 von 1
    • Solder the outer wire braid shield to the ground point.
  6. Xelio P1001A-BK Wi-Fi Antenna Replacement: Schritt 6, Bild 1 von 1
    • Solder the center conductor to the antenna point.
Abschluss
Josh Saenz
316 Reputation
3 Anleitungen geschrieben
Colorado Springs, Team 4-2, Panko Spring 2015 Mitglied von Colorado Springs, Team 4-2, Panko Spring 2015
UCCS-PANKO-S15S4G2
3 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 5
Letzte 30 Tage: 7
Insgesamt: 153
