Einleitung
Use this guide to replace the battery in your Xiaomi Air 12.
Was du brauchst
Orient the computer so the Xiaomi logo is at the bottom of the device.
Insert the plastic opening tool underneath the top-middle rubber covering and lift upwards to reveal the hidden screw.
Remove the eight 3 mm screws using the Torx T5 driver by inserting the screwdriver into each screw and rotating counterclockwise.
Insert the plastic opening tool into each side of the computer and push the tool downwards to pop open the back cover.
Detach the white and black speaker wires by pulling them from the small black tabs along the perimeter of the metal bracket.
Detach the red wire from the tabs on the perimeter of the metal bracket.
Use a PH1 screwdriver to remove the five 2mm black screws.
Remove two silver 1mm JIS #00 screws.
10 weitere Nutzer:innen haben diese Anleitung absolviert.
6 Kommentare
I got to pull out my bloated battery…. Though it could work with just the charger on stand by but it did not… Anyone knows where I can purchase new battery? Can't bring it to the shop because of quarantine but need to work from home.
I removed the bloated battery too. It can’t power on properly. The power light just just on and off around every 5 seconds. Is yours the same?
sdot -
after I change the battery it always says plugged in not charge, anyone has the same issue?
Hi. There is no page for keyboard replacement so I'm asking my question here: how can I find a keyboard replacement for my mi 12.5 notebook? Only two buttons do not work.
