Zum Hauptinhalt wechseln
Xiaomi Mi 3 Rear Facing Camera Replacement
Was du brauchst
  1. Xiaomi Mi 3 Rear Facing Camera Replacement, Battery: Schritt 1, Bild 1 von 3 Xiaomi Mi 3 Rear Facing Camera Replacement, Battery: Schritt 1, Bild 2 von 3 Xiaomi Mi 3 Rear Facing Camera Replacement, Battery: Schritt 1, Bild 3 von 3
    • Firmly press the SIM card removal tool into the hole located at the top of the phone to eject the SIM card tray from the slot.
  2. Xiaomi Mi 3 Rear Facing Camera Replacement: Schritt 2, Bild 1 von 2 Xiaomi Mi 3 Rear Facing Camera Replacement: Schritt 2, Bild 2 von 2
    • Remove the two Phillips head screws located at the top of the phone on either side where the SIM card was ejected.
    • One screw is located under an orange sticker which would serve as your warranty for the camera were this practice not illegal as per the Magnuson–Moss Warranty Act of 1975.
  3. Xiaomi Mi 3 Rear Facing Camera Replacement: Schritt 3, Bild 1 von 3 Xiaomi Mi 3 Rear Facing Camera Replacement: Schritt 3, Bild 2 von 3 Xiaomi Mi 3 Rear Facing Camera Replacement: Schritt 3, Bild 3 von 3
    • Insert a pry tool into the upper edge of the phone, where there is a small gap between screen and frame of the phone to begin separating the screen from the rest of the phone.
    • Be careful when using the pry tool as it can damage the phone's screen or other components.
  4. Xiaomi Mi 3 Rear Facing Camera Replacement: Schritt 4, Bild 1 von 3 Xiaomi Mi 3 Rear Facing Camera Replacement: Schritt 4, Bild 2 von 3 Xiaomi Mi 3 Rear Facing Camera Replacement: Schritt 4, Bild 3 von 3
    • Once the pry tool has been inserted into the phone, slide it around the perimeter of the phone while gently lifting until the screen panel and back panel of the phone separate.
  5. Xiaomi Mi 3 Rear Facing Camera Replacement: Schritt 5, Bild 1 von 2 Xiaomi Mi 3 Rear Facing Camera Replacement: Schritt 5, Bild 2 von 2
    • The back of the phone should now be separated from the screen.
  6. Xiaomi Mi 3 Rear Facing Camera Replacement: Schritt 6, Bild 1 von 3 Xiaomi Mi 3 Rear Facing Camera Replacement: Schritt 6, Bild 2 von 3 Xiaomi Mi 3 Rear Facing Camera Replacement: Schritt 6, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    • Place the front panel screen side down with the camera at the top.
    • Remove these six Phillips head screws located at the upper half of the phone.
    • This screw is located under an orange sticker at the top right corner of the panel. The sticker can be removed with a pair of tweezers, then remove that Phillips head screw.
  7. Xiaomi Mi 3 Rear Facing Camera Replacement: Schritt 7, Bild 1 von 1
    • Next, remove these three screws located at the bottom of the back panel.
  8. Xiaomi Mi 3 Rear Facing Camera Replacement: Schritt 8, Bild 1 von 2 Xiaomi Mi 3 Rear Facing Camera Replacement: Schritt 8, Bild 2 von 2
    • Using tweezers, remove the rubber dust cover on the back panel of the phone.
  9. Xiaomi Mi 3 Rear Facing Camera Replacement: Schritt 9, Bild 1 von 3 Xiaomi Mi 3 Rear Facing Camera Replacement: Schritt 9, Bild 2 von 3 Xiaomi Mi 3 Rear Facing Camera Replacement: Schritt 9, Bild 3 von 3
    • Remove the plastic cover on the bottom of the back panel by inserting the pry tool at the edge and gently lifting.
  10. Xiaomi Mi 3 Rear Facing Camera Replacement: Schritt 10, Bild 1 von 3 Xiaomi Mi 3 Rear Facing Camera Replacement: Schritt 10, Bild 2 von 3 Xiaomi Mi 3 Rear Facing Camera Replacement: Schritt 10, Bild 3 von 3
    • Remove the upper plastic cover from the back panel by inserting the pry tool into the upper edge and gently lifting.
    • Some models have the NFC antenna at the back of the battery glued to the top cover. It is not possible to remove the top cover without removing the battery as well. For these models, check the touchscreen guide for instructions.
  11. Xiaomi Mi 3 Rear Facing Camera Replacement: Schritt 11, Bild 1 von 3 Xiaomi Mi 3 Rear Facing Camera Replacement: Schritt 11, Bild 2 von 3 Xiaomi Mi 3 Rear Facing Camera Replacement: Schritt 11, Bild 3 von 3
    • Using a spudger, remove the small ribbon cable that is connected to the battery.
  12. Xiaomi Mi 3 Rear Facing Camera Replacement: Schritt 12, Bild 1 von 3 Xiaomi Mi 3 Rear Facing Camera Replacement: Schritt 12, Bild 2 von 3 Xiaomi Mi 3 Rear Facing Camera Replacement: Schritt 12, Bild 3 von 3
    • Remove the battery by gripping and pull up on the "Battery Removal" tab attached to the left side of the battery on the back panel.
    • Some force may be required to remove the battery since it is adhered to the phone with two pieces of double sided tape.
  13. Xiaomi Mi 3 Rear Facing Camera Replacement: Schritt 13, Bild 1 von 1
    • The battery is now removed from the panel.
  14. Xiaomi Mi 3 Rear Facing Camera Replacement, Motherboard: Schritt 14, Bild 1 von 2 Xiaomi Mi 3 Rear Facing Camera Replacement, Motherboard: Schritt 14, Bild 2 von 2
    • Disconnect the antenna wire that is attached to the lower left side of the motherboard using the pry tool.
  15. Xiaomi Mi 3 Rear Facing Camera Replacement: Schritt 15, Bild 1 von 3 Xiaomi Mi 3 Rear Facing Camera Replacement: Schritt 15, Bild 2 von 3 Xiaomi Mi 3 Rear Facing Camera Replacement: Schritt 15, Bild 3 von 3
    • Use a pry tool to separate the LCD display cable from the motherboard. The cable connects to the motherboard as a rectangular metallic piece at the bottom right of the motherboard.
  16. Xiaomi Mi 3 Rear Facing Camera Replacement: Schritt 16, Bild 1 von 2 Xiaomi Mi 3 Rear Facing Camera Replacement: Schritt 16, Bild 2 von 2
    • Disconnect the gold ribbon cable for the LCD display by gently inserting the pry tool under the wide end and lifting up.
  17. Xiaomi Mi 3 Rear Facing Camera Replacement: Schritt 17, Bild 1 von 3 Xiaomi Mi 3 Rear Facing Camera Replacement: Schritt 17, Bild 2 von 3 Xiaomi Mi 3 Rear Facing Camera Replacement: Schritt 17, Bild 3 von 3
    • Separate a cable ribbon from the top right of the motherboard by gently inserting the pry tool under the rectangular metallic piece and lifting.
  18. Xiaomi Mi 3 Rear Facing Camera Replacement: Schritt 18, Bild 1 von 3 Xiaomi Mi 3 Rear Facing Camera Replacement: Schritt 18, Bild 2 von 3 Xiaomi Mi 3 Rear Facing Camera Replacement: Schritt 18, Bild 3 von 3
    • Separate a cable ribbon from the top right of the motherboard - near the cable from the previous step - by gently inserting the pry tool under the rectangular metallic piece and lifting.
  19. Xiaomi Mi 3 Rear Facing Camera Replacement: Schritt 19, Bild 1 von 3 Xiaomi Mi 3 Rear Facing Camera Replacement: Schritt 19, Bild 2 von 3 Xiaomi Mi 3 Rear Facing Camera Replacement: Schritt 19, Bild 3 von 3
    • Using a pry tool, gently lift the side control buttons assembly away from the case. They should be loosely connected to the motherboard.
  20. Xiaomi Mi 3 Rear Facing Camera Replacement: Schritt 20, Bild 1 von 2 Xiaomi Mi 3 Rear Facing Camera Replacement: Schritt 20, Bild 2 von 2
    • Remove these two screws.
  21. Xiaomi Mi 3 Rear Facing Camera Replacement: Schritt 21, Bild 1 von 3 Xiaomi Mi 3 Rear Facing Camera Replacement: Schritt 21, Bild 2 von 3 Xiaomi Mi 3 Rear Facing Camera Replacement: Schritt 21, Bild 3 von 3
    • Remove the motherboard from the panel carefully. Use the pry tool as a lever from the top of the panel and lift if from that side.
  22. Xiaomi Mi 3 Rear Facing Camera Replacement: Schritt 22, Bild 1 von 1
    • The motherboard has now been successfully removed.
  23. Xiaomi Mi 3 Rear Facing Camera Replacement, Rear Facing Camera: Schritt 23, Bild 1 von 2 Xiaomi Mi 3 Rear Facing Camera Replacement, Rear Facing Camera: Schritt 23, Bild 2 von 2
    • After removing the motherboard, use a pry tool to gently remove the camera's ribbon cable from the motherboard.
  24. Xiaomi Mi 3 Rear Facing Camera Replacement: Schritt 24, Bild 1 von 1
    • The rear facing camera is now removed from the panel successfully.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Tyler Howard
705 Reputation
4 Anleitungen geschrieben
USF Tampa, Team 1-5, Remmell Fall 2015 Mitglied von USF Tampa, Team 1-5, Remmell Fall 2015
USFT-REMMELL-F15S1G5
4 Mitglieder
6 Anleitungen geschrieben
1 Kommentar zur Anleitung
Is Possible tO charge the camera spare part with the advanced one from mi4i or newer.
ary - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 8
Letzte 30 Tage: 23
Insgesamt: 2,342
