Einleitung
If the back cover of your Xiaomi Mi Mix 2 got shattered or damaged, you can follow this video to replace the broken battery cover. This video shows you the replacement procedure step by step.
Was du brauchst
Videoanleitungen
Fast fertig!
Abschluss
2 Kommentare
¿Is it the same replacement for the Mi Mix 2 SE (Special Edition) ? If it isn’t, could you provide it? Thanks you
David - Antwort
I’m also interested in changing the battery of my Mi Mix 2 SE (full ceramic cover) It has two screws on the bottom, but I really don’t know if it’s possible to take out the cover just unscrewing
Pablo Sahagun - Antwort
