Einleitung
Use this guide to remove the battery from your Xiaomi Mi Pad.
Was du brauchst
Remove the micro SD card slot from the left side of the device using either the metal pin included with the device or a SIM card eject tool.
Use a plastic opening tool and/or opening pick to gently pry the back panel away from the device. Work your way around the device, slowly increasing the gap.
Remove the twelve 3.0 mm Phillips #000 screws on the upper cover of the device.
Carefully pry around the perimeter of the battery with a plastic opening tool to loosen the adhesive securing the battery to the device.
If you disconnected all three connectors, the charging port ribbon cable may have a small amount of adhesive securing it to the battery. Gently pry the cable free of the battery and lift the battery up and out of the device.
18 weitere Nutzer:innen haben diese Anleitung absolviert.
12 Kommentare
Please please make a video for it. I need it desperately.
