Zum Hauptinhalt wechseln
Xiaomi Mi Pad Headphone Jack Replacement
Was du brauchst
  1. Xiaomi Mi Pad Headphone Jack Replacement, Rear Case Assembly: Schritt 1, Bild 1 von 1
    • Remove the micro SD card slot from the left side of the device using either the metal pin included with the device or a SIM card eject tool.
  2. Xiaomi Mi Pad Headphone Jack Replacement: Schritt 2, Bild 1 von 2 Xiaomi Mi Pad Headphone Jack Replacement: Schritt 2, Bild 2 von 2
    • Use a plastic opening tool and/or opening pick to gently pry the back panel away from the device. Work your way around the device, slowly increasing the gap.
    • The back panel has small clips and light adhesive that easily releases from the device.
  3. Xiaomi Mi Pad Headphone Jack Replacement, Headphone Jack: Schritt 3, Bild 1 von 2 Xiaomi Mi Pad Headphone Jack Replacement, Headphone Jack: Schritt 3, Bild 2 von 2
    • Remove the twelve 3.0 mm Phillips #000 screws on the upper cover of the device.
  4. Xiaomi Mi Pad Headphone Jack Replacement: Schritt 4, Bild 1 von 1
    • Remove the upper cover from the device.
  5. Xiaomi Mi Pad Headphone Jack Replacement: Schritt 5, Bild 1 von 1
    • Use a plastic opening tool to pull up and remove the headphone jack from the upper cover.
    • Insert the corner of a plastic opening tool into the port of the headphone jack for easier removal.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Rene Mendoza
311 Reputation
2 Anleitungen geschrieben
USF Tampa, Team 12-5, Blackwell Fall 2015 Mitglied von USF Tampa, Team 12-5, Blackwell Fall 2015
USFT-BLACKWELL-F15S12G5
3 Mitglieder
13 Anleitungen geschrieben
Ein Kommentar
And where to buy? :-(
marcusvoag - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 13
Insgesamt: 2,443
