Einleitung
Use this guide to remove the motherboard from your Xiaomi Mi Pad.
Was du brauchst
Remove the micro SD card slot from the left side of the device using either the metal pin included with the device or a SIM card eject tool.
Use a plastic opening tool and/or opening pick to gently pry the back panel away from the device. Work your way around the device, slowly increasing the gap.
Remove the twelve 3 mm Phillips #00 screws on the upper cover of the device.
Remove the two 3.0 mm Phillips #00 screws securing the motherboard to the device.
Disconnect the six ribbon cables attached to the motherboard using a plastic opening tool.
12 weitere Personen haben diese Anleitung absolviert.
4 Kommentare
It's my email
amaank987321.msk@gmail.com
i'm looking to buy a motherboard for my died mi pad and i couldn't find it any were. Do you know were i can bay one , please help
