Zum Hauptinhalt wechseln
Xiaomi Mi Pad Motherboard Replacement
Was du brauchst
  1. Xiaomi Mi Pad Motherboard Replacement, Rear Case Assembly: Schritt 1, Bild 1 von 1
    • Remove the micro SD card slot from the left side of the device using either the metal pin included with the device or a SIM card eject tool.
  2. Xiaomi Mi Pad Motherboard Replacement: Schritt 2, Bild 1 von 2 Xiaomi Mi Pad Motherboard Replacement: Schritt 2, Bild 2 von 2
    • Use a plastic opening tool and/or opening pick to gently pry the back panel away from the device. Work your way around the device, slowly increasing the gap.
    • The back panel has small clips and light adhesive that easily releases from the device.
  3. Xiaomi Mi Pad Motherboard Replacement, Motherboard: Schritt 3, Bild 1 von 2 Xiaomi Mi Pad Motherboard Replacement, Motherboard: Schritt 3, Bild 2 von 2
    • Remove the twelve 3 mm Phillips #00 screws on the upper cover of the device.
  4. Xiaomi Mi Pad Motherboard Replacement: Schritt 4, Bild 1 von 1
    • Remove the upper cover from the device.
  5. Xiaomi Mi Pad Motherboard Replacement: Schritt 5, Bild 1 von 1
    • Remove the two 3.0 mm Phillips #00 screws securing the motherboard to the device.
  6. Xiaomi Mi Pad Motherboard Replacement: Schritt 6, Bild 1 von 2 Xiaomi Mi Pad Motherboard Replacement: Schritt 6, Bild 2 von 2
    • Disconnect the six ribbon cables attached to the motherboard using a plastic opening tool.
  7. Xiaomi Mi Pad Motherboard Replacement: Schritt 7, Bild 1 von 1
    • Carefully remove the motherboard from the device.
Abschluss
12 weitere Nutzer:innen haben diese Anleitung absolviert.
USF Tampa, Team 12-5, Blackwell Fall 2015 Mitglied von USF Tampa, Team 12-5, Blackwell Fall 2015
USFT-BLACKWELL-F15S12G5
3 Mitglieder
13 Anleitungen geschrieben
4 Kommentare
It's my email
amaank987321.msk@gmail.com
MSK DIGITAL MEDIA - Antwort
i'm looking to buy a motherboard for my died mi pad and i couldn't find it any were. Do you know were i can bay one , please help
Vasile Postolache - Antwort
I want mi pad mother board
Where I buy
Sunil - Antwort
where can i buy matherboard for Xiaomi Mi Pad 4 ?
guyv1975 - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 11
Letzte 30 Tage: 49
Insgesamt: 6,582
