Einleitung
Use this guide to remove the ambient light sensor in your Xiaomi Redmi 2 for repair or replacement.
Was du brauchst
Use the flat end of the spudger to remove the back panel from the mid-frame and front body.
Insert your finger into the curved opening of the mid-frame.
Lift the battery and remove.
Remove twelve 3.4 mm Phillips #000 screws securing the mid-frame to the front body.
Slide the spudger between the mid-frame and front body, gradually prying the two bodies apart as you slide the spudger around the perimeter of the phone.
Remove the 3.4 mm Phillips #000 screw that holds the motherboard to the front body.
Using one prong of the tweezers, pry back the brown clip located on top of the LCD ribbon connector.
Using one prong of the tweezers, pry the ribbon clip away from the motherboard.
Using one prong of the tweezers, lift and pry back the metal clip positioned over the front proximity sensor ribbon connector.
Using one prong of the tweezers, lift and loosen the edge of the ambient light sensor from the motherboard.
17 weitere Personen haben diese Anleitung absolviert.
