Zum Hauptinhalt wechseln
Xiaomi Redmi Note 3 Disassembly Guide
Was du brauchst
  1. Xiaomi Redmi Note 3 Disassembly Guide, Eject the Sim Card Tray: Schritt 1, Bild 1 von 2 Xiaomi Redmi Note 3 Disassembly Guide, Eject the Sim Card Tray: Schritt 1, Bild 2 von 2
    • Locate the sim card tray at the right side of the phone
    • Insert the metal needle sim tool into the tray hole to eject the tray and pull it out
  2. Xiaomi Redmi Note 3 Disassembly Guide, Remove Phone Panel: Schritt 2, Bild 1 von 1
    • Insert your thumb in between the back panel and the front of phone and slowly follow along the edges to separate the two pieces
  3. Xiaomi Redmi Note 3 Disassembly Guide, Disconnect the Connector: Schritt 3, Bild 1 von 1
    • Remove the plastic connector that links the battery with the motherboard by gently prying the ends of the connector from each side of the phone
  4. Xiaomi Redmi Note 3 Disassembly Guide, Begin Battery Removal: Schritt 4, Bild 1 von 1
    • Pull the black tab at the top left of the battery to disconnect the battery from the system
  5. Xiaomi Redmi Note 3 Disassembly Guide, Remove Battery: Schritt 5, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    • Wedge the tweezers under the battery to lift it up
    • Remove as much as adhesive as needed to lift the battery from phone using tweezers or fingers
    • Adhesive that binds the battery to the phone can be strong and this may require a little bit of effort to remove the battery
  6. Xiaomi Redmi Note 3 Disassembly Guide, Unscrew Speaker: Schritt 6, Bild 1 von 1
    • Use the screwdriver to unscrew the speaker at the bottom back of the phone. There are five screws around the edges of the speaker
  7. Xiaomi Redmi Note 3 Disassembly Guide, Detach Speaker: Schritt 7, Bild 1 von 1
    • Remove the loud speaker cover using the tweezers to expose the daughterboard
  8. Xiaomi Redmi Note 3 Disassembly Guide, Remove Daughterboard: Schritt 8, Bild 1 von 2 Xiaomi Redmi Note 3 Disassembly Guide, Remove Daughterboard: Schritt 8, Bild 2 von 2
    • Remove the two gold tabs on the two top corners of the daughterboard
    • Pry the daughterboard open with the tweezers or pull it out using your fingers
    • There is a heat shield underneath the daughter board and it can get hot from charging the phone so make sure you don’t touch it
  9. Xiaomi Redmi Note 3 Disassembly Guide, Begin to Remove Camera: Schritt 9, Bild 1 von 1
    • Unscrew the four screws at the top of the motherboard and pop up the top cover
    • One screw might by disguised by a sticker so locate that and remove the sticker as well
    • Pulling the top cover without removing all the screws might damage the motherboard
  10. Xiaomi Redmi Note 3 Disassembly Guide, Remove Camera Cushion: Schritt 10, Bild 1 von 1
    • Remove the rubber cover that’s containing the camera
  11. Xiaomi Redmi Note 3 Disassembly Guide, Remove Front Camera Protector: Schritt 11, Bild 1 von 1
    • Pull the tab that’s holding the front camera to remove the camera protector
    • To keep the camera from damage hold the camera from the corner and not from the middle of it
  12. Xiaomi Redmi Note 3 Disassembly Guide, Remove Camera: Schritt 12, Bild 1 von 1
    • Pull out the front camera using tweezers or your fingers
  13. Xiaomi Redmi Note 3 Disassembly Guide, Remove Motherboard Connectors: Schritt 13, Bild 1 von 1
    • Remove the five connectors of the motherboard using tweezers or your fingers
  14. Xiaomi Redmi Note 3 Disassembly Guide, Remove Motherboard: Schritt 14, Bild 1 von 1
    • Remove the remaining four screws as your work down to the bottom to loosen the motherboard
  15. Xiaomi Redmi Note 3 Disassembly Guide, Admire Disassembled Phone: Schritt 15, Bild 1 von 1
    • Congrats -- You disassembled the Xiaomi Redmi Note 3!
Abschluss
Meaghan Owens
241 Reputation
1 Anleitung geschrieben
1 Kommentar zur Anleitung
Memory ic problem
Sure - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 49
Insgesamt: 1,533
