Einleitung
This guide demonstrates how to remove the motherboard from your Xiaomi Redmi Note phone. The motherboard is the "brain" of your phone and houses many integral components. Removing the motherboard is also necessary to replace your phone's screen.
Was du brauchst
Insert the plastic opening tool between the charging port and the rear case.
Pry the end of the rear case up from the charging port.
Run the plastic opening tool along the seam on the side of the phone to remove the rear casing.
Locate the indentation at the bottom of the battery.
Place a finger in the indentation and lift up to remove the battery.
Insert a plastic opening into the seam between the midframe and the bottom frame of the phone.
Run the plastic opening tool along the seam.
Pry up the midframe with the plastic opening tool.
Once the midframe has been sufficiently lifted with the tool, place a hand underneath the edge to lift the entire component out of the frame.
Use tweezers to lift the retaining flap of the zero insertion force (ZIF) connector to the upright position.
Use tweezers to pull the ribbon cable out of the ZIF connector.
Remove the front-facing camera from the motherboard.
Disconnect the rear-facing camera from the motherboard by pulling out the press-fit connector to its left.
Use tweezers to lift the retaining flap on the ZIF connector to the upright position.
Pull the ribbon cable out of the connector by pulling to the left.
Repeat these steps for the other two ZIF connectors.
Locate the antenna cable on the bottom right of the motherboard and use tweezers to lift the cable off of the motherboard.
Flip over the motherboard to reveal the back.
Use a plastic opening tool to pry off the snap fit connector, located on the bottom right off of the motherboard.
Lift up the motherboard and turn it over to place it by the side of the phone.
15 weitere Nutzer:innen haben diese Anleitung absolviert.
5 Kommentare
Good explanation, but the question is : Where to get Xiaomi replacement motherboards ?
Besten Dank an alle für Die Mühe, die sie sich jeweils geben um verständliche Anleitungen zu erstellen,
