Zum Hauptinhalt wechseln
XtremeMac Luna Dock Circuit Board Replacement
Was du brauchst
  1. XtremeMac Luna Dock Circuit Board Replacement, Bottom Panel: Schritt 1, Bild 1 von 3 XtremeMac Luna Dock Circuit Board Replacement, Bottom Panel: Schritt 1, Bild 2 von 3 XtremeMac Luna Dock Circuit Board Replacement, Bottom Panel: Schritt 1, Bild 3 von 3
    • Flip the device over so that the batteries are closest to you.
    • Remove the battery lid by pressing the battery cover's tab and pulling it away from the device.
    • Push the battery against the spring and lift it out of the casing.
    • Repeat with the other battery.
  2. XtremeMac Luna Dock Circuit Board Replacement: Schritt 2, Bild 1 von 1
    • Unscrew all eight 12mm Phillips head screws with a Philips #1 screwdriver.
    • The iFixit 26 bit screwdriver kit will not reach the screws. Make sure to use a screwdriver that is thin enough to not get stuck in the screw holes.
  3. XtremeMac Luna Dock Circuit Board Replacement: Schritt 3, Bild 1 von 2 XtremeMac Luna Dock Circuit Board Replacement: Schritt 3, Bild 2 von 2
    • Flip the Luna back over so that the buttons are facing upward and the LCD screen is facing you.
    • Gently tilt the lid back 45 degrees so that the inside is exposed.
    • Be mindful of the wires inside of the Luna. It is easy to break a connection if a wire gets caught.
  4. XtremeMac Luna Dock Circuit Board Replacement, Dock Circuit Board: Schritt 4, Bild 1 von 3 XtremeMac Luna Dock Circuit Board Replacement, Dock Circuit Board: Schritt 4, Bild 2 von 3 XtremeMac Luna Dock Circuit Board Replacement, Dock Circuit Board: Schritt 4, Bild 3 von 3
    • Unscrew the four black 7mm screws with the Phillips #1 screw driver that hold the middle circuit board to the top case.
Abschluss
Matt Ducasse
12 Reputation
3 Anleitungen geschrieben
Cal Poly, Team 3-47, Amido Spring 2013 Mitglied von Cal Poly, Team 3-47, Amido Spring 2013
CPSU-AMIDO-S13S3G47
4 Mitglieder
8 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 4
Insgesamt: 465
