Zum Hauptinhalt wechseln
XtremeMac Luna LCD Display Replacement
Was du brauchst
  1. XtremeMac Luna LCD Display Replacement, Bottom Panel: Schritt 1, Bild 1 von 3 XtremeMac Luna LCD Display Replacement, Bottom Panel: Schritt 1, Bild 2 von 3 XtremeMac Luna LCD Display Replacement, Bottom Panel: Schritt 1, Bild 3 von 3
    • Flip the device over so that the batteries are closest to you.
    • Remove the battery lid by pressing the battery cover's tab and pulling it away from the device.
    • Push the battery against the spring and lift it out of the casing.
    • Repeat with the other battery.
  2. XtremeMac Luna LCD Display Replacement: Schritt 2, Bild 1 von 1
    • Unscrew all eight 12mm Phillips head screws with a Philips #1 screwdriver.
    • The iFixit 26 bit screwdriver kit will not reach the screws. Make sure to use a screwdriver that is thin enough to not get stuck in the screw holes.
  3. XtremeMac Luna LCD Display Replacement: Schritt 3, Bild 1 von 2 XtremeMac Luna LCD Display Replacement: Schritt 3, Bild 2 von 2
    • Flip the Luna back over so that the buttons are facing upward and the LCD screen is facing you.
    • Gently tilt the lid back 45 degrees so that the inside is exposed.
    • Be mindful of the wires inside of the Luna. It is easy to break a connection if a wire gets caught.
  4. XtremeMac Luna LCD Display Replacement, Dock Circuit Board: Schritt 4, Bild 1 von 3 XtremeMac Luna LCD Display Replacement, Dock Circuit Board: Schritt 4, Bild 2 von 3 XtremeMac Luna LCD Display Replacement, Dock Circuit Board: Schritt 4, Bild 3 von 3
    • Unscrew the four black 7mm screws with the Phillips #1 screw driver that hold the middle circuit board to the top case.
  5. XtremeMac Luna LCD Display Replacement, Button Circuit Boards: Schritt 5, Bild 1 von 2 XtremeMac Luna LCD Display Replacement, Button Circuit Boards: Schritt 5, Bild 2 von 2
    • Unscrew the three 7 mm black screws using the Philips #1 screwdriver on the back end of the left and right circuit board.
    • Removing the right circuit board first will make it easier to unscrew the left because the heat-sinks on the left circuit board can get in the way of the screwdriver.
  6. XtremeMac Luna LCD Display Replacement: Schritt 6, Bild 1 von 3 XtremeMac Luna LCD Display Replacement: Schritt 6, Bild 2 von 3 XtremeMac Luna LCD Display Replacement: Schritt 6, Bild 3 von 3
    • Use a plastic opening tool to pry the black connections away from the top casing.
    • Be attentive when you separate the circuit boards from the top, as there is a loose wheel inside.
  7. XtremeMac Luna LCD Display Replacement: Schritt 7, Bild 1 von 2 XtremeMac Luna LCD Display Replacement: Schritt 7, Bild 2 von 2
    • Turn the circuit boards over. Remove the two connections on the left side by pulling on the tabs.
    • The glue that holds the connection together will come off when you pull. Pull on the tab with enough force to break the glue without damaging the wires.
  8. XtremeMac Luna LCD Display Replacement, Speakers: Schritt 8, Bild 1 von 2 XtremeMac Luna LCD Display Replacement, Speakers: Schritt 8, Bild 2 von 2
    • Unscrew four 7mm Phillips screws from the base of each speaker unit.
  9. XtremeMac Luna LCD Display Replacement: Schritt 9, Bild 1 von 3 XtremeMac Luna LCD Display Replacement: Schritt 9, Bild 2 von 3 XtremeMac Luna LCD Display Replacement: Schritt 9, Bild 3 von 3
    • Lift the speakers up out of the Luna chassis.
  10. XtremeMac Luna LCD Display Replacement, LCD Display: Schritt 10, Bild 1 von 2 XtremeMac Luna LCD Display Replacement, LCD Display: Schritt 10, Bild 2 von 2
    • Unscrew two 10mm silver screws at the base of the LCD screen to free it from the chassis.
  11. XtremeMac Luna LCD Display Replacement: Schritt 11, Bild 1 von 2 XtremeMac Luna LCD Display Replacement: Schritt 11, Bild 2 von 2
    • Gently pull up on the LCD screen to remove it.
Abschluss
Matt Ducasse
12 Reputation
3 Anleitungen geschrieben
Cal Poly, Team 3-47, Amido Spring 2013 Mitglied von Cal Poly, Team 3-47, Amido Spring 2013
CPSU-AMIDO-S13S3G47
4 Mitglieder
8 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 12
Insgesamt: 388
