Zum Hauptinhalt wechseln
XtremeMac Luna Motherboard Replacement
Was du brauchst
  1. XtremeMac Luna Motherboard Replacement, Bottom Panel: Schritt 1, Bild 1 von 3 XtremeMac Luna Motherboard Replacement, Bottom Panel: Schritt 1, Bild 2 von 3 XtremeMac Luna Motherboard Replacement, Bottom Panel: Schritt 1, Bild 3 von 3
    • Flip the device over so that the batteries are closest to you.
    • Remove the battery lid by pressing the battery cover's tab and pulling it away from the device.
    • Push the battery against the spring and lift it out of the casing.
    • Repeat with the other battery.
  2. XtremeMac Luna Motherboard Replacement: Schritt 2, Bild 1 von 1
    • Unscrew all eight 12mm Phillips head screws with a Philips #1 screwdriver.
    • The iFixit 26 bit screwdriver kit will not reach the screws. Make sure to use a screwdriver that is thin enough to not get stuck in the screw holes.
  3. XtremeMac Luna Motherboard Replacement: Schritt 3, Bild 1 von 2 XtremeMac Luna Motherboard Replacement: Schritt 3, Bild 2 von 2
    • Flip the Luna back over so that the buttons are facing upward and the LCD screen is facing you.
    • Gently tilt the lid back 45 degrees so that the inside is exposed.
    • Be mindful of the wires inside of the Luna. It is easy to break a connection if a wire gets caught.
  4. XtremeMac Luna Motherboard Replacement, Dock Circuit Board: Schritt 4, Bild 1 von 3 XtremeMac Luna Motherboard Replacement, Dock Circuit Board: Schritt 4, Bild 2 von 3 XtremeMac Luna Motherboard Replacement, Dock Circuit Board: Schritt 4, Bild 3 von 3
    • Unscrew the four black 7mm screws with the Phillips #1 screw driver that hold the middle circuit board to the top case.
  5. XtremeMac Luna Motherboard Replacement, Button Circuit Boards: Schritt 5, Bild 1 von 2 XtremeMac Luna Motherboard Replacement, Button Circuit Boards: Schritt 5, Bild 2 von 2
    • Unscrew the three 7 mm black screws using the Philips #1 screwdriver on the back end of the left and right circuit board.
    • Removing the right circuit board first will make it easier to unscrew the left because the heat-sinks on the left circuit board can get in the way of the screwdriver.
  6. XtremeMac Luna Motherboard Replacement: Schritt 6, Bild 1 von 3 XtremeMac Luna Motherboard Replacement: Schritt 6, Bild 2 von 3 XtremeMac Luna Motherboard Replacement: Schritt 6, Bild 3 von 3
    • Use a plastic opening tool to pry the black connections away from the top casing.
    • Be attentive when you separate the circuit boards from the top, as there is a loose wheel inside.
  7. XtremeMac Luna Motherboard Replacement: Schritt 7, Bild 1 von 2 XtremeMac Luna Motherboard Replacement: Schritt 7, Bild 2 von 2
    • Turn the circuit boards over. Remove the two connections on the left side by pulling on the tabs.
    • The glue that holds the connection together will come off when you pull. Pull on the tab with enough force to break the glue without damaging the wires.
  8. XtremeMac Luna Motherboard Replacement, Motherboard: Schritt 8, Bild 1 von 2 XtremeMac Luna Motherboard Replacement, Motherboard: Schritt 8, Bild 2 von 2
    • Disconnect the white cables on the front of the radio jack.
  9. XtremeMac Luna Motherboard Replacement: Schritt 9, Bild 1 von 3 XtremeMac Luna Motherboard Replacement: Schritt 9, Bild 2 von 3 XtremeMac Luna Motherboard Replacement: Schritt 9, Bild 3 von 3
    • Carefully remove the radio jack from the casing by pushing on the back connections.
    • Gently remove the motherboard from the casing. Be careful with the display housing.
Abschluss
David Ellison
18 Reputation
3 Anleitungen geschrieben
Cal Poly, Team 3-47, Amido Spring 2013 Mitglied von Cal Poly, Team 3-47, Amido Spring 2013
CPSU-AMIDO-S13S3G47
4 Mitglieder
8 Anleitungen geschrieben
Ein Kommentar
Where can i buy a motherboard to replace a broken one? What type of a motherboard should I buy? No idea at all.
Iris - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 13
Insgesamt: 654
