Einleitung
If your Luna is no longer picking up radio signals, it may be due to a faulty radio jack. Replace it in a few simple steps.
Was du brauchst
Flip the device over so that the batteries are closest to you.
Remove the battery lid by pressing the battery cover's tab and pulling it away from the device.
Push the battery against the spring and lift it out of the casing.
Repeat with the other battery.
Flip the Luna back over so that the buttons are facing upward and the LCD screen is facing you.
Gently tilt the lid back 45 degrees so that the inside is exposed.
Unscrew the four black 7mm screws with the Phillips #1 screw driver that hold the middle circuit board to the top case.
Unscrew the three 7 mm black screws using the Philips #1 screwdriver on the back end of the left and right circuit board.
Use a plastic opening tool to pry the black connections away from the top casing.
Turn the circuit boards over. Remove the two connections on the left side by pulling on the tabs.
Remove the two 12mm Phillips head screws from the back of the device using a Phillips #1 screwdriver.
Turn the Luna so that the display faces forward.
Pull the two white tabs to remove the cables from the front of the radio jack.
Push the connections through the back casing and lift the radio jack up and out.
Desolder the positive connection (red) and the negative connection (black) on top of the radio jack to completely remove it.
