Zum Hauptinhalt wechseln
Yamaha FG-425 Guitar String Replacement
Was du brauchst
  1. Yamaha FG-425 Guitar String Replacement, Guitar String: Schritt 1, Bild 1 von 3 Yamaha FG-425 Guitar String Replacement, Guitar String: Schritt 1, Bild 2 von 3 Yamaha FG-425 Guitar String Replacement, Guitar String: Schritt 1, Bild 3 von 3
    • Turn the tuning peg clockwise using the All-In-1 Restringing Tool’s peg winder to loosen the tension of the strings.
    • Unwind the string from the tuning post and remove the string.
    • Caution: Be careful when removing the string from the tuning post because you may hurt your fingers while doing so.
  2. Yamaha FG-425 Guitar String Replacement: Schritt 2, Bild 1 von 2 Yamaha FG-425 Guitar String Replacement: Schritt 2, Bild 2 von 2
    • Use the pin remover in the All-In-1 Restringing Tool to remove the pin from the bridge
    • Remove the string from the bridge hole.
  3. Yamaha FG-425 Guitar String Replacement: Schritt 3, Bild 1 von 2 Yamaha FG-425 Guitar String Replacement: Schritt 3, Bild 2 von 2
    • Bend the string end on the string ball.
    • Place the string into the bridge hole.
  4. Yamaha FG-425 Guitar String Replacement: Schritt 4, Bild 1 von 3 Yamaha FG-425 Guitar String Replacement: Schritt 4, Bild 2 von 3 Yamaha FG-425 Guitar String Replacement: Schritt 4, Bild 3 von 3
    • Place the bridge pin into the bridge hole.
    • Gently pull the string while pushing the pin into the hole.
  5. Yamaha FG-425 Guitar String Replacement: Schritt 5, Bild 1 von 2 Yamaha FG-425 Guitar String Replacement: Schritt 5, Bild 2 von 2
    • Insert the string through the tuning post hole.
    • Pull the string about half an inch or an inch through the tuning post.
    • Ensure that the string is lined up with the nut.
  6. Yamaha FG-425 Guitar String Replacement: Schritt 6, Bild 1 von 1
    • Use the All-In-1 Restringing Tool's peg winder to turn the tuning peg counterclockwise to slightly tighten the strings.
  7. Yamaha FG-425 Guitar String Replacement: Schritt 7, Bild 1 von 1
    • Cut any excess strings on the tuning post using the All-In-1 Restringing Tool’s clippers.
Ziellinie
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Nicole Francheska Letigio
207 Reputation
1 Anleitung geschrieben
York University, Team S1-G19, Woodhouse Winter 2021 Mitglied von York University, Team S1-G19, Woodhouse Winter 2021
YORK-WOODHOUSE-W21S1G19
1 Mitglied
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 4
Letzte 30 Tage: 19
Insgesamt: 252
