Einleitung
This guide explains the method to repair or replace damaged wires on the Yamaha NS‑AW190BL.
Was du brauchst
Remove the six Phillips Head 1.2mm screws on the front side of the speaker.
Crack open both parts of the casing carefully.
Using a plastic opening tool, wedge open the bottom of the speaker to separate the two parts of the speaker.
Remove the cooling foam.
Use a metal spudger to push the tab in on the red wire.
Repeat the process for the blue wire.
The blue wire can now be removed from its connector.
Remove the red wire to free the rear casing.
Use the metal spudger to bend down the metal tabs that hold the wires to the terminals. The tabs are small and in between the grooves of the terminal.
Use the metal spudger to bend the metal tabs that hold the connectors to the terminals.
