Einleitung
Use this guide to replace the Yamaha NS-AW190BL rear casing.
Was du brauchst
Remove the six Phillips Head 1.2mm screws on the front side of the speaker.
Crack open both parts of the casing carefully.
Using a plastic opening tool, wedge open the bottom of the speaker to separate the two parts of the speaker.
Remove the cooling foam.
Use a metal spudger to push the tab in on the red wire.
Repeat the process for the blue wire.
The blue wire can now be removed from its connector.
Remove the red wire to free the rear casing.
