Zum Hauptinhalt wechseln
Yamaha YPG-225 Keys Replacement
Was du brauchst
  1. Yamaha YPG-225 Keys Replacement, Batteries: Schritt 1, Bild 1 von 1
    • Turn the keyboard over so that the keys are facing the ground.
    Frag FixBot
    Kommentar hinzufügen
  2. Yamaha YPG-225 Keys Replacement: Schritt 2, Bild 1 von 1
    • Pop the tabs on the battery casing and remove it from the back plate.
    Frag FixBot
  3. Yamaha YPG-225 Keys Replacement: Schritt 3, Bild 1 von 1
    • Locate the six batteries and remove them from the battery cavity.
    Frag FixBot
  4. Yamaha YPG-225 Keys Replacement, Faceplate: Schritt 4, Bild 1 von 1
    • Remove the six 10mm screws at the top of the backplate.
    Frag FixBot
  5. Yamaha YPG-225 Keys Replacement: Schritt 5, Bild 1 von 1
    • Remove the seven 12mm screws in the middle of the back plate.
    Frag FixBot
  6. Yamaha YPG-225 Keys Replacement: Schritt 6, Bild 1 von 1
    • Remove the eight 10mm screws from the side and the bottom of the back plate.
    Frag FixBot
  7. Yamaha YPG-225 Keys Replacement: Schritt 7, Bild 1 von 1
    • As the face plate is no longer connected to the body of the keyboard, be careful to not drop the body when performing this step.
    • Flip over the keyboard.
    Frag FixBot
  8. Yamaha YPG-225 Keys Replacement: Schritt 8, Bild 1 von 2 Yamaha YPG-225 Keys Replacement: Schritt 8, Bild 2 von 2
    • Lifting from the front and the back of the face plate equally, pull the face plate up and then back, away from the keyboard.
    • Be careful when removing the face plate. There are wires attached.
    Frag FixBot
  9. Yamaha YPG-225 Keys Replacement, Keys: Schritt 9, Bild 1 von 1
    • Remove the 32mm screws that hold keys down.
    • Depending on which block of keys you wish to remove, there may be four screws instead of three.
    Frag FixBot
  10. Yamaha YPG-225 Keys Replacement: Schritt 10, Bild 1 von 1
    • Remove the block of keys that holds the key you wish to install.
    • To do this, apply a small force away from the top of the keys and slightly toward the floor.
    • If done correctly, the block of keys will come to a slight downward angle.
    Frag FixBot
  11. Yamaha YPG-225 Keys Replacement: Schritt 11, Bild 1 von 2 Yamaha YPG-225 Keys Replacement: Schritt 11, Bild 2 von 2
    • Press the tab on the back side of the block of keys out and detach the black keys.
    Frag FixBot
  12. Yamaha YPG-225 Keys Replacement: Schritt 12, Bild 1 von 1
    • Remove the individual white key(s) or the black key set(s) that require replacement.
    Frag FixBot
Abschluss
7 weitere Personen haben diese Anleitung absolviert.
Cal Poly, Team 2-62, Propen Fall 2012 Mitglied von Cal Poly, Team 2-62, Propen Fall 2012
CPSU-PROPEN-F12S2G62
2 Mitglieder
6 Anleitungen geschrieben
3 Kommentare zur Anleitung
Excellent, Although I've got a different type of yamaha keyboard, still good inside info.
Diederick Fokker - Antwort Teilen
Great article. Thank you so much.
Andreas Devig - Antwort Teilen
The instructions were very good and easy to understand. Question on the same subject. How about keys that have popped up on the key bed.
Donald Bryant - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 11
Letzte 30 Tage: 67
Insgesamt: 21,889
