Einleitung
Overheating is a common issue with motorcycles, often caused by cooling fan failure. This problem is easy to fix and requires only a few tools. To complete this repair, you will need a #1 Phillips-head screwdriver, a flat-head screwdriver, and a hex key set, specifically with a 10mm Allen key.
Was du brauchst
Use your motorcycle's key to open the rear seat, and remove the seat to access the tool pouch.
Using a Phillips-head screwdriver, remove the screws attached to the battery terminals.
Remove the middle fairing on the left-hand side, and carefully unclip the turn signal cable.
Once you have removed the left-hand cover under the clutch lever, locate the relay assemblies for the lights and cooling fans.
Use a flat-head screwdriver to gently pry the locking mechanism open on the relay assembly. You can remove the relay by itself or with the bracket assembly.
