Einleitung
Are you having trouble hearing your child through the YOTON YB02 baby monitor? If so, here’s a guide on how to replace the monitor’s speaker and solve your problem. The monitor speaker on the YB02 baby monitor is used to help parents hear their child's needs from another room. This feature on the YOTON YB02 is very important to help parents monitor their child. Before checking this guide, try to turn off and restart your baby monitor to confirm the speaker is faulty.
Was du brauchst
Use a Phillips #0 screwdriver to remove the four 7 mm screws from the back panel of the monitor.
Using the plastic tool, disconnect the cables connecting the speaker to the motherboard.
