Zum Hauptinhalt wechseln
Yujin Robot iCLEBO Arte Dust Bin Replacement
Was du brauchst
  1. Yujin Robot iCLEBO Arte Dust Bin Replacement, Dust Bin: Schritt 1, Bild 1 von 1
    • Remove the dust bin by gently pressing the silver button on top of the vacuum until the bin releases.
  2. Yujin Robot iCLEBO Arte Dust Bin Replacement: Schritt 2, Bild 1 von 2 Yujin Robot iCLEBO Arte Dust Bin Replacement: Schritt 2, Bild 2 von 2
    • Grip the bottom of the dust bin. Push up on the tabs as indicated by the yellow arrows.
    • Empty contents of bin into waste receptacle and rinse with water as needed.
Abschluss
To reassemble the dust bin, follow these instructions in reverse order.
Trent Treiber
204 Reputation
2 Anleitungen geschrieben
USF Tampa, Team S2-G3, Nance Spring 2017 Mitglied von USF Tampa, Team S2-G3, Nance Spring 2017
USFT-NANCE-S17S2G3
4 Mitglieder
14 Anleitungen geschrieben
3 Kommentare
My machine says C3 even though the dust bin is successfully in place. Now what? Works fine on hardwood floors.
Amy Abbiatti - Antwort
C3 error even though dustbin is installed correctly. Works fine on hardwood floors. Now what?
I also get C3 error when dustbin is clean and installed correctly - now what?
Philip Melese - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 5
Letzte 30 Tage: 15
Insgesamt: 1,088
