Einleitung
This guide will show users how to empty the vacuum's dust bin when it is full and replace it if damaged.
Was du brauchst
Remove the dust bin by gently pressing the silver button on top of the vacuum until the bin releases.
Grip the bottom of the dust bin. Push up on the tabs as indicated by the yellow arrows.
Empty contents of bin into waste receptacle and rinse with water as needed.
To reassemble the dust bin, follow these instructions in reverse order.
3 Kommentare
My machine says C3 even though the dust bin is successfully in place. Now what? Works fine on hardwood floors.
C3 error even though dustbin is installed correctly. Works fine on hardwood floors. Now what?
I also get C3 error when dustbin is clean and installed correctly - now what?
