Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Einleitung
Is your drone not functioning the way you want it to? Consider using this guide to replace the motherboard in your drone.
  1. Before you begin start by putting on a ESD wrist strap to prevent ESD damage and remove the battery. Flip over the drone so that the propellers are facing down and the camera is facing up.
    • Before you begin start by putting on a ESD wrist strap to prevent ESD damage and remove the battery.
    • Flip over the drone so that the propellers are facing down and the camera is facing up.
  2. Grip the cover that covers the rest of the wires, and give it a slight pull to remove it. Grip the cover that covers the rest of the wires, and give it a slight pull to remove it. Grip the cover that covers the rest of the wires, and give it a slight pull to remove it.
    • Grip the cover that covers the rest of the wires, and give it a slight pull to remove it.
  3. Remove the 4 rubber plugs that hold the drone and its internal parts together.
    • Remove the 4 rubber plugs that hold the drone and its internal parts together.
    • These plugs can be located in each corner of the drone, and are white.
  4. Das Essential Toolkit
    Die nützlichsten Werkzeuge in unserem kompaktesten Kit.
    Jetzt kaufen
    Jetzt kaufen
  5. Unplug the four cables that are connected on the top face of the frame.
    • Unplug the four cables that are connected on the top face of the frame.
  6. The rest of the wires that are still connected can be unplugged. Using a pair of tweezers they can be unplugged.
    • The rest of the wires that are still connected can be unplugged.
    • Using a pair of tweezers they can be unplugged.
  7. Lift up or tilt entire frame and mother board and unplug all the wires. Lift up or tilt entire frame and mother board and unplug all the wires. Lift up or tilt entire frame and mother board and unplug all the wires.
    • Lift up or tilt entire frame and mother board and unplug all the wires.
  8. The battery connector has two wires connected to a plug in with two little screws. Unscrew the two screws and pull it apart using a small tweezers. Unscrew the two screws and pull it apart using a small tweezers.
    • The battery connector has two wires connected to a plug in with two little screws.
    • Unscrew the two screws and pull it apart using a small tweezers.
  9. Flip over the frame and mother board and unscrew the mother board.
    • Flip over the frame and mother board and unscrew the mother board.
    • There are four screws on each corner of the mother board.
  10. After the screws are out, the motherboard can be pulled out softly with hands. Remove the motherboard from the device.
    • After the screws are out, the motherboard can be pulled out softly with hands.
    • Remove the motherboard from the device.
Abschluss
4 weitere Nutzer haben diese Anleitung absolviert.
Ryanne Millis
300 Reputation
1 Anleitung geschrieben
UW Stout, Team S6-G5, Ogden Fall 2018 Mitglied von UW Stout, Team S6-G5, Ogden Fall 2018
UWSTOUT-OGDEN-F18S6G5
4 Mitglieder
4 Anleitungen geschrieben
Excellent step by step instructions.
paul_courville - Antwort
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 1
Letzten 7 Tage: 4
Letzten 30 Tage: 34
Insgesamt: 1,275
