Zum Hauptinhalt wechseln
Yuneec Breeze 4K Motherboard Replacement
Was du brauchst
  1. Yuneec Breeze 4K Motherboard Replacement, Motherboard M7: Schritt 1, Bild 1 von 2 Yuneec Breeze 4K Motherboard Replacement, Motherboard M7: Schritt 1, Bild 2 von 2
    • Before you begin start by putting on a ESD wrist strap to prevent ESD damage and remove the battery.
    • Flip over the drone so that the propellers are facing down and the camera is facing up.
  2. Yuneec Breeze 4K Motherboard Replacement: Schritt 2, Bild 1 von 3 Yuneec Breeze 4K Motherboard Replacement: Schritt 2, Bild 2 von 3 Yuneec Breeze 4K Motherboard Replacement: Schritt 2, Bild 3 von 3
    • Grip the cover that covers the rest of the wires, and give it a slight pull to remove it.
  3. Yuneec Breeze 4K Motherboard Replacement: Schritt 3, Bild 1 von 1
    • Remove the 4 rubber plugs that hold the drone and its internal parts together.
    • These plugs can be located in each corner of the drone, and are white.
  4. Yuneec Breeze 4K Motherboard Replacement: Schritt 4, Bild 1 von 1
    • Unplug the four cables that are connected on the top face of the frame.
  5. Yuneec Breeze 4K Motherboard Replacement: Schritt 5, Bild 1 von 2 Yuneec Breeze 4K Motherboard Replacement: Schritt 5, Bild 2 von 2
    • The rest of the wires that are still connected can be unplugged.
    • Using a pair of tweezers they can be unplugged.
  6. Yuneec Breeze 4K Motherboard Replacement: Schritt 6, Bild 1 von 3 Yuneec Breeze 4K Motherboard Replacement: Schritt 6, Bild 2 von 3 Yuneec Breeze 4K Motherboard Replacement: Schritt 6, Bild 3 von 3
    • Lift up or tilt entire frame and mother board and unplug all the wires.
  7. Yuneec Breeze 4K Motherboard Replacement: Schritt 7, Bild 1 von 3 Yuneec Breeze 4K Motherboard Replacement: Schritt 7, Bild 2 von 3 Yuneec Breeze 4K Motherboard Replacement: Schritt 7, Bild 3 von 3
    • The battery connector has two wires connected to a plug in with two little screws.
    • Unscrew the two screws and pull it apart using a small tweezers.
  8. Yuneec Breeze 4K Motherboard Replacement: Schritt 8, Bild 1 von 1
    • Flip over the frame and mother board and unscrew the mother board.
    • There are four screws on each corner of the mother board.
  9. Yuneec Breeze 4K Motherboard Replacement: Schritt 9, Bild 1 von 2 Yuneec Breeze 4K Motherboard Replacement: Schritt 9, Bild 2 von 2
    • After the screws are out, the motherboard can be pulled out softly with hands.
    • Remove the motherboard from the device.
Abschluss
5 weitere Nutzer:innen haben diese Anleitung absolviert.
UW Stout, Team S6-G5, Ogden Fall 2018 Mitglied von UW Stout, Team S6-G5, Ogden Fall 2018
UWSTOUT-OGDEN-F18S6G5
4 Mitglieder
4 Anleitungen geschrieben
Ein Kommentar
Excellent step by step instructions.
paul_courville - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 12
Insgesamt: 1,932
