Einleitung
This device page will explain how to properly replace the joysticks. The joysticks play an important role to the Yuneec ST10 Plus, as it is the main control function of the device.
Was du brauchst
Flip the controller upside down to access the battery compartment.
Grab the compartment door and pull down.
Gently lift the blue tab connected to the battery in order to remove the battery from its housing.
To disconnect the battery from the remote, grab the red and black connectors.
Pull gently on connectors until they disconnect.
Slide the Jimmy underneath the rubber grips and pry upwards.
With your free hand grasp the rubber grips and pull upward to remove it.
Remove the six 1.3 cm screws located on the back panel of the remote using the 5.5mm hex screw bit.
Carefully pull up and over on the back panel to remove. Take your time because there are wires connecting the two panels that can be easily torn.
Use the nylon tipped tweezers to pull the two joystick cables from their connectors.
With the 5mm hex diver bit, remove the eight 10mm screws surrounding both joysticks.
