Zum Hauptinhalt wechseln
Yuneec Typhoon H Gimbal Bushing Reattachment
Was du brauchst
  1. Yuneec Typhoon H Gimbal Bushing Reattachment, Gimbal Bushing Connectors to Camera Mount: Schritt 1, Bild 1 von 2 Yuneec Typhoon H Gimbal Bushing Reattachment, Gimbal Bushing Connectors to Camera Mount: Schritt 1, Bild 2 von 2
    • In order to repair the camera and camera gimbal, remove the camera configuration from the body of the drone.
    • Pull up on the tab connected to the camera configuration and slide the entire apparatus off.
  2. Yuneec Typhoon H Gimbal Bushing Reattachment: Schritt 2, Bild 1 von 3 Yuneec Typhoon H Gimbal Bushing Reattachment: Schritt 2, Bild 2 von 3 Yuneec Typhoon H Gimbal Bushing Reattachment: Schritt 2, Bild 3 von 3
    • Put the gimbal bushings (the rubber balls) back into the plastic alignment mounts.
    • The circle that is separated from the main body of the bushing should then be inserted into the hole.
    • When pushing these bushings back into place, it is smart to use a skinny tool or toothpick.
Abschluss
To reassemble your device, simply slide the camera mount back onto the bottom of the drone.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Jake Breul
127 Reputation
1 Anleitung geschrieben
Cal Poly, Team S22-G3, Maness Spring 2018 Mitglied von Cal Poly, Team S22-G3, Maness Spring 2018
CPSU-MANESS-S18S22G3
4 Mitglieder
5 Anleitungen geschrieben
3 Kommentare
Camera not getting power after crash.
Don - Antwort
Crashed drone and camera not getting power anymore. Nothing appears to be broken.
Don - Antwort
Did steps. Bushings ok. Camera still won't communicate.
vickiesamus - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 2
Letzte 30 Tage: 9
Insgesamt: 1,603
