Einleitung
This guide will demonstrate how to put the camera apparatus back together on a Yuneec Typhoon H, if it has come apart.
Was du brauchst
In order to repair the camera and camera gimbal, remove the camera configuration from the body of the drone.
Pull up on the tab connected to the camera configuration and slide the entire apparatus off.
Put the gimbal bushings (the rubber balls) back into the plastic alignment mounts.
The circle that is separated from the main body of the bushing should then be inserted into the hole.
To reassemble your device, simply slide the camera mount back onto the bottom of the drone.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
