Einleitung
After a crash of the Yuneec Typhoon Q500 4K the camera on the drone is susceptible to breaking. One of the most common problems after a crash is the camera breaks or doesn't it turn on. This guide will instruct you on how to fix the drones camera.
Was du brauchst
Have a look at the wires that are connected to the camera.
Sometimes after a crash the wires are pulled out or torn upon impact. Check to see the state of them.
If they are torn or camera just isn't working, a piece is needed to override the broken wires.
If the previous solution didn’t work, a replacement camera may be necessary. To replace it, slide the entire camera off the drone frame.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
