Zum Hauptinhalt wechseln
ZD-N Plus Wireless Controller Motherboard Replacement
Was du brauchst
  1. ZD-N Plus Wireless Controller Motherboard Replacement, Back Panel: Schritt 1, Bild 1 von 1
    • Remove the seven 12mm JIS #00 screws that hold the back panel in place.
    Frag FixBot
    Kommentar hinzufügen
  2. ZD-N Plus Wireless Controller Motherboard Replacement: Schritt 2, Bild 1 von 2 ZD-N Plus Wireless Controller Motherboard Replacement: Schritt 2, Bild 2 von 2
    • Lift up on the back panel of the ZD-N Plus to remove it from the rest of the controller.
    Frag FixBot
  3. ZD-N Plus Wireless Controller Motherboard Replacement, Battery: Schritt 3, Bild 1 von 1
    • Use an opening tool to pry the battery from its original position.
    • The battery is glued on, so this may take some effort.
    Frag FixBot
  4. ZD-N Plus Wireless Controller Motherboard Replacement: Schritt 4, Bild 1 von 2 ZD-N Plus Wireless Controller Motherboard Replacement: Schritt 4, Bild 2 von 2
    • Use an opening tool to pry the connector away from the two metallic prongs.
    • The parts are built to stay together, so this may take some effort.
    • Be careful to not warp the prongs in the process.
    Frag FixBot
  5. ZD-N Plus Wireless Controller Motherboard Replacement: Schritt 5, Bild 1 von 2 ZD-N Plus Wireless Controller Motherboard Replacement: Schritt 5, Bild 2 von 2
    • Remove the battery from the controller.
    Frag FixBot
  6. ZD-N Plus Wireless Controller Motherboard Replacement, Rumble Motor: Schritt 6, Bild 1 von 2 ZD-N Plus Wireless Controller Motherboard Replacement, Rumble Motor: Schritt 6, Bild 2 von 2
    • Remove the electrical connector attaching each rumble motor to the controller.
    • Lift up on the circular section of the rumble to remove it from the controller.
    Frag FixBot
  7. ZD-N Plus Wireless Controller Motherboard Replacement, Motherboard: Schritt 7, Bild 1 von 2 ZD-N Plus Wireless Controller Motherboard Replacement, Motherboard: Schritt 7, Bild 2 von 2
    • Remove the three 1.2mm JIS #00 screws that hold the motherboard in place.
    Frag FixBot
  8. ZD-N Plus Wireless Controller Motherboard Replacement: Schritt 8, Bild 1 von 1
    • Lift the motherboard out of the controller.
    Frag FixBot
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 8
Letzte 30 Tage: 23
Insgesamt: 480
