Einleitung
This guide will show you how to replace the camera in case it breaks or no longer works.
Was du brauchst
Remove the back cover of the phone to expose the phone's mid-frame.
Use the Phillips Head 00 screw driver to unscrew the seven 0.1mm screws along the perimeter of the phone's mid frame.
Wedge the flat end of the spudger between the mid frame and the digitizer.
Gently pry the mid frame away from the rest of the phone to expose the motherboard.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
