Einleitung
Caution! Ribbons should NOT be torn when disassembling the motherboard from the phone! Use tweezers to GENTLY wiggle the ribbons back and forth to loosen and separate ribbons from the motherboard and phone.
Was du brauchst
Remove the back cover of the phone to expose the phone's mid-frame.
Use the Phillips Head 00 screw driver to unscrew the seven 0.1mm screws from the phone's mid frame.
Wedge the flat end of the spudger between the mid frame and the digitizer.
Gently pry the mid frame away from the rest of the phone to expose the motherboard.
In diesem Schritt verwendetes Werkzeug:Tweezers$4.99
Use the tweezers to remove the four ribbon wires on the sides of the device.
Remove the connector to free the motherboard from the screen.
5 weitere Personen haben diese Anleitung absolviert.
