Zum Hauptinhalt wechseln
ZTE Blade Spark Rear-Facing Camera
  1. ZTE Blade Spark Rear-Facing Camera, ZTE Blade Spark Rear-Facing Camera: Schritt 1, Bild 1 von 1
    • First, apply heat evenly on the back cover using a heat sack to soften the adhesive.
  2. ZTE Blade Spark Rear-Facing Camera: Schritt 2, Bild 1 von 1
    • Now, carefully remove the back cover.
  3. ZTE Blade Spark Rear-Facing Camera: Schritt 3, Bild 1 von 1
    • Once opened, Locate and remove all exposed screws using a Phillips-Head screwdriver and set them aside.
  4. ZTE Blade Spark Rear-Facing Camera: Schritt 4, Bild 1 von 1
    • To remove the inner white panel/cover, use a plastic opening tool to loosen from each side.
  5. ZTE Blade Spark Rear-Facing Camera: Schritt 5, Bild 1 von 1
    • After removing the white plastic panel, you should see a black metal battery cover.
    • To remove the metal battery cover, remove the screws from the panel using a Phillips screwdriver if you have not yet done so.
  6. ZTE Blade Spark Rear-Facing Camera: Schritt 6, Bild 1 von 1
    • Then, simple lift to remove the metal battery cover.
  7. ZTE Blade Spark Rear-Facing Camera: Schritt 7, Bild 1 von 1
    • You have reached the Fingerprint Scanner, the device Battery, and Front Facing Camera.
  8. ZTE Blade Spark Rear-Facing Camera: Schritt 8, Bild 1 von 3 ZTE Blade Spark Rear-Facing Camera: Schritt 8, Bild 2 von 3 ZTE Blade Spark Rear-Facing Camera: Schritt 8, Bild 3 von 3
    • Proceeding with disassembly, next up is the top chipset which the Rear Facing Camera is attached to.
    • To detach the chipset and reach the Rear Camera, locate and disconnect five power connectors surrounding the top chipset (as shown in images).
  9. ZTE Blade Spark Rear-Facing Camera: Schritt 9, Bild 1 von 1
    • Once you have the power connectors disconnected from the top chipset, use a Phillips screwdriver to remove the final screw located at the very top of the chipset (as shown in image).
  10. ZTE Blade Spark Rear-Facing Camera: Schritt 10, Bild 1 von 1
    • Then, simply lift chipset from top and detach from the device frame.
  11. ZTE Blade Spark Rear-Facing Camera: Schritt 11, Bild 1 von 1
    • You have now reached the final replacement component of the device, the Rear Facing Camera!
    • For step-by-step instructions on replacing any of the device components covered throughout the disassembly process, check out our ZTE Blade Spark Replacement guides.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Hung Vu
632 Reputation
1 Anleitung geschrieben
Gateway, Team S1-G6, Johnson Spring 2018 Mitglied von Gateway, Team S1-G6, Johnson Spring 2018
GCC-JOHNSON-S18S1G6
2 Mitglieder
2 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 12
Letzte 30 Tage: 27
Insgesamt: 2,262
