Zum Hauptinhalt wechseln
Einleitung
Follow this guide to replace the Fingerprint Scanner for the ZTE Blade Spark. To get to this step please see ZTE Blade Spark Disassembly Guide
Ersatzteile
Keine Ersatzteile angegeben.
  1. Remove the Fingerprint Scanner:
    • Remove the Fingerprint Scanner:
    • Gently lift to disconnect the scanner's power connector from the device main frame.
  2. MacBook Akku Fix Kits
    Ab $69.99
    Buy Now
    Ab $69.99
    Buy Now
  3. Now that the scanner and device back panel is detached from the back of the device , push the scanner through from the front side of the back cover.
    • Now that the scanner and device back panel is detached from the back of the device , push the scanner through from the front side of the back cover.
    • Once you have done so, set aside.
Abschluss
To reassemble your device, follow the instructions on the ZTE Blade Spark Disassembly guide in reverse order.
Hung Vu
600 Reputation
5 Anleitungen geschrieben
Gateway, Team S1-G6, Johnson Spring 2018 Mitglied von Gateway, Team S1-G6, Johnson Spring 2018
GCC-JOHNSON-S18S1G6
2 Mitglieder
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 8
Insgesamt: 65
