Zum Hauptinhalt wechseln
ZTE Blade Spark Screen Replacement
Was du brauchst
  1. ZTE Blade Spark Screen Replacement, Screen: Schritt 1, Bild 1 von 1
    • Place phone screen side down on a flat surface.
  2. ZTE Blade Spark Screen Replacement: Schritt 2, Bild 1 von 2 ZTE Blade Spark Screen Replacement: Schritt 2, Bild 2 von 2
    • Take an opening tool, and insert it between the phone's backplate and chassis.
    • Work the tool all the way around perimeter of the phone until the backplate is free.
  3. ZTE Blade Spark Screen Replacement: Schritt 3, Bild 1 von 1
    • Use a Phillips #00 screwdriver to carefully remove all fifteen 3.0 mm screws.
  4. ZTE Blade Spark Screen Replacement: Schritt 4, Bild 1 von 1
    • Remove the middle plate that was unscrewed from the previous step.
    • At this stage you should have 3 separate parts as shown.
    • For the next step you will be working on the middle part in this picture.
  5. ZTE Blade Spark Screen Replacement: Schritt 5, Bild 1 von 1
    • Take black covering off of battery.
  6. ZTE Blade Spark Screen Replacement: Schritt 6, Bild 1 von 2 ZTE Blade Spark Screen Replacement: Schritt 6, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    • Unclip fastener located in the red box. Blunt end tweezers are recommended for this process.
  7. ZTE Blade Spark Screen Replacement: Schritt 7, Bild 1 von 2 ZTE Blade Spark Screen Replacement: Schritt 7, Bild 2 von 2
    • Remove battery so you are left with the base of the phone, the battery, and the battery cover separated.
  8. ZTE Blade Spark Screen Replacement: Schritt 8, Bild 1 von 1
    • Remove the 4mm screws in the 2 red circles shown with the Phillips #00 screwdriver.
  9. ZTE Blade Spark Screen Replacement: Schritt 9, Bild 1 von 1
    • Heat all 4 sides of the piece with the iOpener to loosen adhesive.
  10. ZTE Blade Spark Screen Replacement: Schritt 10, Bild 1 von 2 ZTE Blade Spark Screen Replacement: Schritt 10, Bild 2 von 2
    • Now remove the screen from it's base using the opening tool.
Abschluss
Swap your old screen with your new screen. To reassemble your device with a new screen, follow these instructions in reverse order.
Solomon Barket
181 Reputation
1 Anleitung geschrieben
IUPUI, Team 1-3, Harley Spring 2023 Mitglied von IUPUI, Team 1-3, Harley Spring 2023
IUPUI-HARLEY-S23S1G3
3 Mitglieder
4 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 17
Insgesamt: 233
