Einleitung
This guide provides instructions for removing the back cover of the ZTE Blade X Max. You will have to use heating products to complete this guide. If you are using the iFixit iOpener, or a heating pad, be sure to follow the instructions for that particular product.
Was du brauchst
Use the iOpener or heating pad to heat around the edges of the phone to melt the adhesive.
Remove the opaque yellow sticker that indicates where the fingerprint scanner is connected to the back of the device.
In diesem Schritt verwendetes Werkzeug:Tweezers$4.99
Remove the two 1mm Phillips #000 screws on the small panel that was underneath the sticker.
Use the tweezers to remove the panel.
Use the tweezers to pull at the base of the film to remove the fingerprint scanner.
Eine weitere Person hat diese Anleitung absolviert.
