Zum Hauptinhalt wechseln
ZTE Blade Z Max Battery Replacement
Was du brauchst
  1. ZTE Blade Z Max Battery Replacement, SIM Card: Schritt 1, Bild 1 von 3 ZTE Blade Z Max Battery Replacement, SIM Card: Schritt 1, Bild 2 von 3 ZTE Blade Z Max Battery Replacement, SIM Card: Schritt 1, Bild 3 von 3
    • Turn the device on it side with the buttons away from you.
    • Using the SIM Card Eject Tool, insert the narrow end into the ejection hole.
    • Press firmly into the hole until the SIM card tray pops out far enough to grab with your fingers.
  2. ZTE Blade Z Max Battery Replacement: Schritt 2, Bild 1 von 3 ZTE Blade Z Max Battery Replacement: Schritt 2, Bild 2 von 3 ZTE Blade Z Max Battery Replacement: Schritt 2, Bild 3 von 3
    • Pull the tray out with your fingers .
    • Remove the SIM card.
  3. ZTE Blade Z Max Battery Replacement, Fingerprint Sensor: Schritt 3, Bild 1 von 1
    • Remove the one T2 screw from the side of the phone near where the SIM card tray was.
  4. ZTE Blade Z Max Battery Replacement: Schritt 4, Bild 1 von 2 ZTE Blade Z Max Battery Replacement: Schritt 4, Bild 2 von 2
    • Insert a plastic opening tool into the space where the SIM card tray used to be.
    • Gently pry the back away form the phone frame until you hear and audible click of the back separating.
  5. ZTE Blade Z Max Battery Replacement: Schritt 5, Bild 1 von 2 ZTE Blade Z Max Battery Replacement: Schritt 5, Bild 2 von 2
    • Insert the plastic opening tool into the space you created between the phone back and frame.
    • Slide the plastic opening tool along the outside of the phone, underneath the back, to separate the rest of the clips holding the back onto the frame.
  6. ZTE Blade Z Max Battery Replacement: Schritt 6, Bild 1 von 2 ZTE Blade Z Max Battery Replacement: Schritt 6, Bild 2 von 2
    • Rotate the back over to the side, being careful not to damage the fingerprint sensor ribbon cable.
    • Use a plastic opening tool to separate the fingerprint sensor from the back of the phone.
    • On reassembly, add a piece of simple scotch tape to hold the fingerprint sensor to the phone back.
    • Set the phone back aside.
  7. ZTE Blade Z Max Battery Replacement: Schritt 7, Bild 1 von 1
    • Remove the 6 silver 2.9mm screws from the back of the phone with a JIS #000 bit.
    • Remove the 11 black 3.5mm screws with the same JIS #000 bit.
  8. ZTE Blade Z Max Battery Replacement: Schritt 8, Bild 1 von 2 ZTE Blade Z Max Battery Replacement: Schritt 8, Bild 2 von 2
    • Turn the phone over, with the screen up.
    • Insert the opening tool between the screen and the silver trim that surrounds it.
    • Run the plastic opening tool around the circumference of the phone to separate the clips of that hold the trim to the frame.
  9. ZTE Blade Z Max Battery Replacement: Schritt 9, Bild 1 von 2 ZTE Blade Z Max Battery Replacement: Schritt 9, Bild 2 von 2
    • Turn the phone back over, with the screen down.
    • Lift the trim piece off of the phone and set aside.
  10. ZTE Blade Z Max Battery Replacement: Schritt 10, Bild 1 von 2 ZTE Blade Z Max Battery Replacement: Schritt 10, Bild 2 von 2
    • Using a plastic opening tool, separate the fingerprint ribbon connector from the motherboard.
  11. ZTE Blade Z Max Battery Replacement, Battery: Schritt 11, Bild 1 von 2 ZTE Blade Z Max Battery Replacement, Battery: Schritt 11, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    • Use a pair of tweezers to carefully pull up on the tape securing the connector.
    • This will undo the connector as well.
  12. ZTE Blade Z Max Battery Replacement: Schritt 12, Bild 1 von 3 ZTE Blade Z Max Battery Replacement: Schritt 12, Bild 2 von 3 ZTE Blade Z Max Battery Replacement: Schritt 12, Bild 3 von 3
    • Be careful to not damage the battery during this step. If it appears you are using too much force to separate the battery from the frame, you may need to heat the phone to soften the adhesive holding the battery to the phone.
    • Starting at the bottom left corner of the battery, use the wide end of the spudger as a wedge to get underneath the battery.
    • Insert a plastic opening tool into the space created by the spudger and CAREFULLY begin to pry around the edge of the battery.
    • Once the battery is separated for enough from the phone, use your hands to fully remove the battery, using the wide end of the spudger to scrape off adhesive where necessary.
Abschluss
6 weitere Personen haben diese Anleitung absolviert.
2 Kommentare
I want to clarify that in step 4 you don’t want to try to separate the back cover in the actual sim card slot but above it between the back cover and the top of the slot.
alan scott - Antwort
I'm not sure what or if it needs too be done I just bought a battery wanted to put in but not sure how to do it myself
hotmama414 - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 18
Letzte 30 Tage: 45
Insgesamt: 6,771
