Zum Hauptinhalt wechseln
ZTE Blade Z Max Side Mounted Buttons Replacement
Was du brauchst
  1. ZTE Blade Z Max Side Mounted Buttons Replacement, SIM Card: Schritt 1, Bild 1 von 3 ZTE Blade Z Max Side Mounted Buttons Replacement, SIM Card: Schritt 1, Bild 2 von 3 ZTE Blade Z Max Side Mounted Buttons Replacement, SIM Card: Schritt 1, Bild 3 von 3
    • Turn the device on it side with the buttons away from you.
    • Using the SIM Card Eject Tool, insert the narrow end into the ejection hole.
    • Press firmly into the hole until the SIM card tray pops out far enough to grab with your fingers.
  2. ZTE Blade Z Max Side Mounted Buttons Replacement: Schritt 2, Bild 1 von 3 ZTE Blade Z Max Side Mounted Buttons Replacement: Schritt 2, Bild 2 von 3 ZTE Blade Z Max Side Mounted Buttons Replacement: Schritt 2, Bild 3 von 3
    • Pull the tray out with your fingers .
    • Remove the SIM card.
  3. ZTE Blade Z Max Side Mounted Buttons Replacement, Fingerprint Sensor: Schritt 3, Bild 1 von 1
    • Remove the one T2 screw from the side of the phone near where the SIM card tray was.
  4. ZTE Blade Z Max Side Mounted Buttons Replacement: Schritt 4, Bild 1 von 2 ZTE Blade Z Max Side Mounted Buttons Replacement: Schritt 4, Bild 2 von 2
    • Insert a plastic opening tool into the space where the SIM card tray used to be.
    • Gently pry the back away form the phone frame until you hear and audible click of the back separating.
  5. ZTE Blade Z Max Side Mounted Buttons Replacement: Schritt 5, Bild 1 von 2 ZTE Blade Z Max Side Mounted Buttons Replacement: Schritt 5, Bild 2 von 2
    • Insert the plastic opening tool into the space you created between the phone back and frame.
    • Slide the plastic opening tool along the outside of the phone, underneath the back, to separate the rest of the clips holding the back onto the frame.
  6. ZTE Blade Z Max Side Mounted Buttons Replacement: Schritt 6, Bild 1 von 2 ZTE Blade Z Max Side Mounted Buttons Replacement: Schritt 6, Bild 2 von 2
    • Rotate the back over to the side, being careful not to damage the fingerprint sensor ribbon cable.
    • Use a plastic opening tool to separate the fingerprint sensor from the back of the phone.
    • On reassembly, add a piece of simple scotch tape to hold the fingerprint sensor to the phone back.
    • Set the phone back aside.
  7. ZTE Blade Z Max Side Mounted Buttons Replacement: Schritt 7, Bild 1 von 1
    • Remove the 6 silver 2.9mm screws from the back of the phone with a JIS #000 bit.
    • Remove the 11 black 3.5mm screws with the same JIS #000 bit.
  8. ZTE Blade Z Max Side Mounted Buttons Replacement: Schritt 8, Bild 1 von 2 ZTE Blade Z Max Side Mounted Buttons Replacement: Schritt 8, Bild 2 von 2
    • Turn the phone over, with the screen up.
    • Insert the opening tool between the screen and the silver trim that surrounds it.
    • Run the plastic opening tool around the circumference of the phone to separate the clips of that hold the trim to the frame.
  9. ZTE Blade Z Max Side Mounted Buttons Replacement: Schritt 9, Bild 1 von 2 ZTE Blade Z Max Side Mounted Buttons Replacement: Schritt 9, Bild 2 von 2
    • Turn the phone back over, with the screen down.
    • Lift the trim piece off of the phone and set aside.
  10. ZTE Blade Z Max Side Mounted Buttons Replacement: Schritt 10, Bild 1 von 2 ZTE Blade Z Max Side Mounted Buttons Replacement: Schritt 10, Bild 2 von 2
    • Using a plastic opening tool, separate the fingerprint ribbon connector from the motherboard.
  11. ZTE Blade Z Max Side Mounted Buttons Replacement, Side Mounted Buttons: Schritt 11, Bild 1 von 2 ZTE Blade Z Max Side Mounted Buttons Replacement, Side Mounted Buttons: Schritt 11, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    • Using a set of tweezers, pull off the small piece of tape on top of the ribbon cable connector on the left side of the motherboard.
  12. ZTE Blade Z Max Side Mounted Buttons Replacement: Schritt 12, Bild 1 von 2 ZTE Blade Z Max Side Mounted Buttons Replacement: Schritt 12, Bild 2 von 2
    • Use a plastic opening tool or spudger to scrape the glue away from the ribbon cable.
  13. ZTE Blade Z Max Side Mounted Buttons Replacement: Schritt 13, Bild 1 von 3 ZTE Blade Z Max Side Mounted Buttons Replacement: Schritt 13, Bild 2 von 3 ZTE Blade Z Max Side Mounted Buttons Replacement: Schritt 13, Bild 3 von 3
    • Using a plastic opening tool or spudger, open the zip connection by prying up on the right (black) side of the connector.
    • Using the tweezers, carefully pull the the ribbon cable out of the connector.
  14. ZTE Blade Z Max Side Mounted Buttons Replacement: Schritt 14, Bild 1 von 2 ZTE Blade Z Max Side Mounted Buttons Replacement: Schritt 14, Bild 2 von 2
    • The button ribbon cable is very fragile, especially near the down volume button. If you intend on reinstalling this piece later, be careful not to rip it.
    • Using a plastic opening tool or tweezers, pry the edge of the button strip away from the phone.
    • Once all of the buttons are free, the whole assembly should simply lift out.
    • Glue may be required to hold the new buttons to the phone.
Abschluss
5 weitere Personen haben diese Anleitung absolviert.
3 Kommentare
can you do a videomplz
corispastries - Antwort
I need help. When I plug the charger in it would turn on but since the power button was broken I had to buy a new one and today I had received it. Now I did everything correctly however, on step 14 I didn't use tweezers since I didn't have any to remove the ribbon and the ribbon didn't get affected but on top where the ribbon goes in at broke. It should still turn on. So I put everything back and put the charger in and it charges but it doesn't show that it's charging now. And whenever I hold the power button the light twitches but the phone doesn't turn on or even show the percent of the battery which never did that until now. Did I do something wrong? Current trying to redo everything.
Tylor Everett - Antwort
I can’t believe I was able to fix this thing! Amazing. Ordered the button, took it apart with my kit and rebuilt it. Not to mention I took apart my Mac ProBook and fixed that too!! Apple Store - It’s hopeless, your data is gone forever. Get a new machine. Best Buy - It’s hopeless, your data is gone forever. Get a new machine.
Nope!
Matt Cave - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 24
Letzte 30 Tage: 34
Insgesamt: 1,646
