Zum Hauptinhalt wechseln
ZTE Compel Battery Replacement
Was du brauchst
  1. ZTE Compel Battery Replacement, Battery: Schritt 1, Bild 1 von 1
    • Place the phone on a flat surface with the screen facing down. This will allow easy access to the removable black plastic cover on the back of the phone.
  2. ZTE Compel Battery Replacement: Schritt 2, Bild 1 von 1
    • In the bottom right corner of the device, use your fingernail to remove the back cover of the phone by lifting up and holding the device with your other hand.
  3. ZTE Compel Battery Replacement: Schritt 3, Bild 1 von 1
    • In the top-right area of the battery, use your fingernail to lift the battery out of the phone.
    • If your battery is corroded, take all necessary precautions, such as, gloves and protective eyewear.
Abschluss
Kidron Stamper
327 Reputation
3 Anleitungen geschrieben
Ohio State, Team S1-G4, Whitney Fall 2018 Mitglied von Ohio State, Team S1-G4, Whitney Fall 2018
OSU-WHITNEY-F18S1G4
2 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 6
Insgesamt: 195
