Einleitung
In this lesson I will be showing you how to replace the screen.
Was du brauchst
Removing screen To remove the screen you must first remove the back cover; afterwards you unscrew everything from the screen, then you detach the cable that connects the screen to the phone, and you will have detached the screen from the rest of the phone.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
