Zum Hauptinhalt wechseln
ZTE Jasper LTE Camera Replacement
Was du brauchst
  1. ZTE Jasper LTE Camera Replacement, Battery: Schritt 1, Bild 1 von 1
    • Insert the spudger into the bottom left corner of the phone.
    • Use the spudger to loosen the back cover.
  2. ZTE Jasper LTE Camera Replacement: Schritt 2, Bild 1 von 1
    • Insert the black spudger near the bottom left of the battery. There will be an opening to easily to remove the battery.
    • Continuing to use tool, prop up the battery and remove it.
  3. ZTE Jasper LTE Camera Replacement, Camera: Schritt 3, Bild 1 von 2 ZTE Jasper LTE Camera Replacement, Camera: Schritt 3, Bild 2 von 2
    • Remove nine 0.8mm Phillips #00 screws.
  4. ZTE Jasper LTE Camera Replacement: Schritt 4, Bild 1 von 2 ZTE Jasper LTE Camera Replacement: Schritt 4, Bild 2 von 2
    • Remove the back cover by pulling upwards.
    • Removing the back cover may take a bit of force.
  5. ZTE Jasper LTE Camera Replacement: Schritt 5, Bild 1 von 3 ZTE Jasper LTE Camera Replacement: Schritt 5, Bild 2 von 3 ZTE Jasper LTE Camera Replacement: Schritt 5, Bild 3 von 3
    • Disconnect the gold component attached to the camera by pulling upwards using the tweezers.
    • Remove the camera using the tweezers by gripping tightly around the camera and pulling upwards.
    • Camera is attached to the motherboard with adhesive. As such, you may need to use light force to remove the camera.
Abschluss
Anthony Sou
391 Reputation
4 Anleitungen geschrieben
UW Tacoma, Team S1-G1, Cardinal Spring 2019 Mitglied von UW Tacoma, Team S1-G1, Cardinal Spring 2019
UWT-CARDINAL-S19S1G1
4 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 3
Insgesamt: 103
