Zum Hauptinhalt wechseln
ZTE Jasper LTE Screen Replacement
Was du brauchst
  1. ZTE Jasper LTE Screen Replacement, Battery: Schritt 1, Bild 1 von 1
    • Insert the spudger into the bottom left corner of the phone.
    • Use the spudger to loosen the back cover.
  2. ZTE Jasper LTE Screen Replacement: Schritt 2, Bild 1 von 1
    • Insert the black spudger near the bottom left of the battery. There will be an opening to easily to remove the battery.
    • Continuing to use tool, prop up the battery and remove it.
  3. ZTE Jasper LTE Screen Replacement, Camera: Schritt 3, Bild 1 von 2 ZTE Jasper LTE Screen Replacement, Camera: Schritt 3, Bild 2 von 2
    • Remove nine 0.8mm Phillips #00 screws.
  4. ZTE Jasper LTE Screen Replacement: Schritt 4, Bild 1 von 2 ZTE Jasper LTE Screen Replacement: Schritt 4, Bild 2 von 2
    • Remove the back cover by pulling upwards.
    • Removing the back cover may take a bit of force.
  5. ZTE Jasper LTE Screen Replacement: Schritt 5, Bild 1 von 3 ZTE Jasper LTE Screen Replacement: Schritt 5, Bild 2 von 3 ZTE Jasper LTE Screen Replacement: Schritt 5, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    • Disconnect the gold component attached to the camera by pulling upwards using the tweezers.
    • Remove the camera using the tweezers by gripping tightly around the camera and pulling upwards.
    • Camera is attached to the motherboard with adhesive. As such, you may need to use light force to remove the camera.
  6. ZTE Jasper LTE Screen Replacement, Screen: Schritt 6, Bild 1 von 1
    • Disconnect all of these parts from the motherboard.
  7. ZTE Jasper LTE Screen Replacement: Schritt 7, Bild 1 von 3 ZTE Jasper LTE Screen Replacement: Schritt 7, Bild 2 von 3 ZTE Jasper LTE Screen Replacement: Schritt 7, Bild 3 von 3
    • Remove the 0.8mm Phillips #00 screw from the bottom right.
    • Disconnect the gold pin by pulling upwards with the tweezers.
  8. ZTE Jasper LTE Screen Replacement: Schritt 8, Bild 1 von 3 ZTE Jasper LTE Screen Replacement: Schritt 8, Bild 2 von 3 ZTE Jasper LTE Screen Replacement: Schritt 8, Bild 3 von 3
    • Lightly disconnect the power button, volume button and the chip from the motherboard.
    • Be careful not to tear the volume and power button off the motherboard.
  9. ZTE Jasper LTE Screen Replacement: Schritt 9, Bild 1 von 2 ZTE Jasper LTE Screen Replacement: Schritt 9, Bild 2 von 2
    • Lightly move clip back to release the motherboard.
    • Gently pull the motherboard away from the screen.
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
Anthony Sou
391 Reputation
4 Anleitungen geschrieben
UW Tacoma, Team S1-G1, Cardinal Spring 2019 Mitglied von UW Tacoma, Team S1-G1, Cardinal Spring 2019
UWT-CARDINAL-S19S1G1
4 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 264
