Einleitung
This guide will describe and show how to replace ZTE Lever lithium ion battery.
  1. Remove the SD card and the Sim card from the device.
    • Remove the SD card and the Sim card from the device.
    • The Sim and SD cards are not shown here as our device did not come with them.
  2. Use an plastic opening tool to separate the back from the device.
    • Use an plastic opening tool to separate the back from the device.
    • Remove the two 1.6mm Phillips #0 screws from the battery plug cover.
    • Remove the cover.
    • Disconnect the battery cable from the motherboard with a plastic opening tool.
    • Use your hands, or a plastic opening tool, to pry the battery from the phone.
Abschluss
Michael Gonzalez
Mitglied seit 29.01.2018
445 Reputation
4 Anleitungen geschrieben
USF Tampa, Team S5-G2, Passmore Spring 2018 Mitglied von USF Tampa, Team S5-G2, Passmore Spring 2018
USFT-PASSMORE-S18S5G2
3 Mitglieder
6 Anleitungen geschrieben
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 9
Letzte 30 Tage: 40
Insgesamt: 286
